Routing Suggestions
mlewi1
I would like to use the HX One with my UAFX Dream, Golden and Starlight Pedals.  Any suggestions on the best setup to maximize the use of the pre/post setting on the HX one?
Well the way approach this would possibly be, if you are using the Dream as the amp/cab part of this setup, then stick any dirt (overdrive, fuzz, compression) before the amp. Then usually your Delay, Reverb and any other time based effects after the amp/cab.
It’s worth bearing in mind, that with any of this stuff, there are no rules - other than if it sounds good, then it is good. Patch the stuff together and experiment. I doubt anything will blow up.
Hope this helps/makes sense.
