Macbook Air M2 running Mac OS sonoma 14.3 does not recognize HD500X
robseeley
After many attempts,  my new Macbook Air M2 does not recognize my HD500X when connected. Everything still works fine with my old Macbook Air (2012).  Apps that no longer work: HD500X Edit, Mainstage, Garage Band.  So I am thinking it is some sort of driver issue. Are there any known issues with HD500X drivers and the new Macbook M1,M2 running Sonoma 14.3 ?
macOS 14 Sonoma Compatibility
is my MacBook Pro with the M1 chip compatible with the LINE6 HD500x
_______________________________________________________________________________________________________________________________________________________________________
All about POD HD500/X
help and useful tips
On 1/28/2024 at 4:31 PM, robseeley said:
So does that mean the HD500X will never work with Sonoma 14.3 or later,  or is there a workaround ?
If you want, try the workaround described in the following post: POD HD500X can't be detected with Catalina (mac)
It seems to have worked also for one with a Mac running OS 14.1.1 Sonoma
Tried the workaround.  The menu options seem to have changed under Sonoma 14.3.  Under privacy and security there is no "general" category.
Did see another note about installing rosetta 2 since HD Edit was written to run on Intel Macs and rosetta 2 is an emulator that allows these apps to run on the new M1/M2 Macs.
Received this message after attempting to install ; " rosetta 2 not supported on this version of Mac OS".  Don't know for sure if this has anything to do with the OS not recognizing the HD500X,  but my next query is to Apple to see if Rosetta 2 has been discontinued or they just forgot to include it in the 14.3 build. Would be nice if Line6 could weigh in on this question.
