mansinthe79 Posted January 28, 2024 Share Posted January 28, 2024 My current setup (which I use for shows at mid to large sized venues) is pod go with an epiphone thunderbird and a headrush frfr112 but it sounds much better when I plug my bass directly to the speaker. I have created a bass rig and it sounds great but still not as good as the direct input from my bass. Am I missing something related to the global eq or some other settings because I never faced these problems as a lead guitarist but recently I’ve made the switch and I’m kind of convinced that the pod go is just not meant for the bass. Any suggestions appreciated Quote Link to comment Share on other sites More sharing options...
theElevators Posted January 29, 2024 Share Posted January 29, 2024 FRFR can tolerate bass frequencies, but only to a certain point. I would simply use a real bass amp, set on a clean setting as a monitor. Bass amps are kind-of PAs by definition, they don't really color the sound (typically), unless you try to sound like Lemmy. Quote Link to comment Share on other sites More sharing options...
