medicinewolf99 Posted February 16, 2024 Share Posted February 16, 2024 I'm having a hard time setting up a wah or vol/wah combo with one expression pedal. It seems that it randomly changes from exp 1 to exp 2. Also sometimes it just gets stuck on a mid wah tone and wont fluctuate(go from 1-100) when I press the wah back and forth. The toe switch doesn't seem to do anything either. All I want is to set up a vol/wah combo for most of my presets.. Any help is appreciated Quote Link to comment Share on other sites More sharing options...
rd2rk Posted February 16, 2024 Share Posted February 16, 2024 I'm using the Mission Engineering SP1-L6 Helix Cable Tip>Out1 Ring>Out2 Global Settings>Preferences EXP/FS Tip = EXP 1 EXP/FS Ring = FS5 - EDIT - FS8 for HXSXL Tip Polarity = Inverted Ring Polarity = Normal Global Settings>EXP Pedals EXP1 Position = Preset EXP2 Position = Preset This configuration places the WAH on EXP Pedal 1 and the Volume on EXP Pedal 2 Quote Link to comment Share on other sites More sharing options...
Schmalle Posted February 16, 2024 Share Posted February 16, 2024 Make sure to use a TRS cable. Quote Link to comment Share on other sites More sharing options...
medicinewolf99 Posted February 17, 2024 Author Share Posted February 17, 2024 can you please link a trs cable so that goes from the stomp unit to both inputs in the pedal? My cable has a stereo end that goes into the stomp and 2 mono ends into each pedal input... I dont understand the tip and ring lingo...I have the same pedal rd2 Quote Link to comment Share on other sites More sharing options...
Schmalle Posted February 17, 2024 Share Posted February 17, 2024 On 2/17/2024 at 1:15 AM, medicinewolf99 said: can you please link a trs cable so that goes from the stomp unit to both inputs in the pedal? My cable has a stereo end that goes into the stomp and 2 mono ends into each pedal input... I dont understand the tip and ring lingo...I have the same pedal rd2 Ignore my post. What you have is already the right cable for the SP1-L6. It might be faulty though. Open it up the stereo plug (=TRS: tip, ring, sleeve) and check whether the tip and ring cables are in danger of having (unwanted) contact. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted February 17, 2024 Share Posted February 17, 2024 On 2/16/2024 at 5:15 PM, medicinewolf99 said: can you please link a trs cable so that goes from the stomp unit to both inputs in the pedal? My cable has a stereo end that goes into the stomp and 2 mono ends into each pedal input... I dont understand the tip and ring lingo...I have the same pedal rd2 Look at the bottom of the pedal. The jacks are labelled OUT 1 and OUT 2. > means "connect this cable to that out". The cable mono leads should be labeled TIP and RING. RING is USUALLY red. Now go into Global Settings and find the settings I described. Set them as I described. If you still don't get it, be specific about what is confusing you. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted February 17, 2024 Share Posted February 17, 2024 On 2/16/2024 at 5:33 PM, medicinewolf99 said: 165 B · 1 download Those are .php files and don't open in Windows. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted February 17, 2024 Share Posted February 17, 2024 Those are still .php files. Quote Link to comment Share on other sites More sharing options...
medicinewolf99 Posted February 17, 2024 Author Share Posted February 17, 2024 for this paramter "EXP/FS Ring = FS5" my only options are exp 2 or FS8... I dont have a FS8 Quote Link to comment Share on other sites More sharing options...
Schmalle Posted February 17, 2024 Share Posted February 17, 2024 FS8 is the name of any footswitch that is connected to the ring of the external footswitch jack. It's what FS5 is on the normal HX Stomp. FS8 is the correct option. 1 Quote Link to comment Share on other sites More sharing options...
medicinewolf99 Posted February 17, 2024 Author Share Posted February 17, 2024 Ok Ive got the wah working...when i press the pedal switch on the toe its still wah...not a volume pedal Quote Link to comment Share on other sites More sharing options...
rd2rk Posted February 17, 2024 Share Posted February 17, 2024 On 2/16/2024 at 6:16 PM, medicinewolf99 said: Ok Ive got the wah working...when i press the pedal switch on the toe its still wah...not a volume pedal You need both a WAH block and a VOLUME block in the signal chain. Quote Link to comment Share on other sites More sharing options...
Schmalle Posted February 17, 2024 Share Posted February 17, 2024 On 2/17/2024 at 2:16 AM, medicinewolf99 said: Ok Ive got the wah working...when i press the pedal switch on the toe its still wah...not a volume pedal Nice. One way is to set Global Settings -> Footswitches -> FS8 Function to TogglEXP. The other (imho better) way is is to set Global Settings -> Footswitches -> FS8 Function to Stomp 8 and assign FS8 to bypass wah and volume (if one is on the other is bypassed) and assign both wah and volume to EXP1 (EXP2 isn't used). This works because to toggle between wah and volume you need to "toe down" the expression pedal which means the volume is full anyways. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted February 17, 2024 Share Posted February 17, 2024 On 2/16/2024 at 6:10 PM, Schmalle said: FS8 is the name of any footswitch that is connected to the ring of the external footswitch jack. It's what FS5 is on the normal HX Stomp. FS8 is the correct option. Edited my post. Thank you! 1 Quote Link to comment Share on other sites More sharing options...
medicinewolf99 Posted February 17, 2024 Author Share Posted February 17, 2024 got it! thanks to both of you for the help! I'm sure ill have more questions later :-) 1 1 Quote Link to comment Share on other sites More sharing options...
