can an HX Effects use my LT's presets, sans-amp modeling?
boynigel
On 3/8/2024 at 1:34 PM, boynigel said:
If I have an LT that I’m using exclusively as an effects processor (no amp/cab modeling).  If I get an HX Effects, can I copy the LT’s effects-only presets, including snapshots, to the HX?
If you have both the LT and FX units, they can simultaneously connect to HX Edit because it has Multi-Device, Multi-Window Support. You should then be able to drag and drop presets between each unit.
Regarding preset compatibility between the LT and HXFX they should work if your LT Preset doesn't exceed the HX Effects Block type and Path count, and DSP limits. Snapshots greater than 4 are discarded. (from the HX Edit Pilot's Guide)
The next time you open HX Edit, click on the “question mark a white circle” in the lower left of the GUI window. There you will find a link to the HX Edit Pilot’s Guide, which is a downloadable Adobe Acrobat pdf. This contains all the relevant information you may require for editing and managing your presets and also a Preset Translation Compatibility Table.
Hope this helps/makes sense.
On 3/8/2024 at 10:16 AM, datacommando said:
Regarding preset compatibility between the LT and HXFX they should work if your LT Preset doesn't exceed the HX Effects Block type and Path count, and DSP limits. Snapshots greater that 4 are discarded. (from the HX Edit Pilot's Guide)
contemplating the purchase of an HX Effects for a secondary rig.  good to know.  ty
