Control Looper from Edit?
Drybonz
On 3/23/2024 at 3:22 PM, Drybonz said:
Is there a way to play and pause the looper playback in Edit while you are working?
From the HX Edit Pilot’s Guide page 36:
Looper Block Options - It is possible to add a Looper type block to a preset, and view and edit several Looper block parameters within the Edit tab. However, it is not possible to toggle the Looper mode of your connected device on and off within the HX Edit application.”
But, you probably realised as soon as you tried to do it, didn’t you?
Hope this helps/makes sense.
