rnrfantasy Posted March 27, 2024 Share Posted March 27, 2024 Hi all...I'm new to the Helix Floor but have also started using it as my audio interface. I used to record using Bias FX 2, and I was able to change amps/etc. at will since I was using a plug-in and the guitar signal was recorded dry. If I'm using the Helix for my guitar tones how can I do that? Won't I be committing that certain guitar sound/amp when I record it? Some other info...I record on a Mac Mini, using Logic and Reaper. Thanks! Quote Link to comment Share on other sites More sharing options...
rd2rk Posted March 27, 2024 Share Posted March 27, 2024 From the manual, USB AUDIO section: Recording a Dry DI Track For this example, we’ll record guitar into two DAW tracks simultaneously, with one capturing the Helix-processed tone and the other the unprocessed DI guitar. 1. In the Helix Global Settings>Ins/Outs>Page 3 screen, set Re-amp Src (USB 7) to “Guitar” (as shown above). 2. Dial in your desired Helix tone, while keeping the Helix Input and Output blocks both set to the default “Multi” setting. 3. Create two new audio tracks in your DAW software project: Create one mono track to record the dry DI guitar, and set the track’s input to Helix USB 7. Continued... 1 1 Quote Link to comment Share on other sites More sharing options...
datacommando Posted March 27, 2024 Share Posted March 27, 2024 On 3/27/2024 at 5:35 AM, rnrfantasy said: Hi all...I'm new to the Helix Floor but have also started using it as my audio interface. I used to record using Bias FX 2, and I was able to change amps/etc. at will since I was using a plug-in and the guitar signal was recorded dry. If I'm using the Helix for my guitar tones how can I do that? Won't I be committing that certain guitar sound/amp when I record it? Some other info...I record on a Mac Mini, using Logic and Reaper. Thanks! Hi, Here’s a video of Pete Thorn doing exactly what you are wanting to achieve - it’s referred to as reamping. Hope this helps/makes sense. 1 Quote Link to comment Share on other sites More sharing options...
rnrfantasy Posted March 28, 2024 Author Share Posted March 28, 2024 Ah perfect...thanks to both of you. I've been reading the manual but missed that. Great video as well! Appreciate it! 1 Quote Link to comment Share on other sites More sharing options...
