Guillee Posted March 31, 2024 Share Posted March 31, 2024 Hello. I tried to update the firmware for Catalyst 60. Line6 Updater gave an error message, it tells me to turn the amplifier off and on and now it won't turn on, as if there is no power. Is this a blockage or coincidence the ignition has been damaged? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted April 1, 2024 Share Posted April 1, 2024 Perform a Factory Reset. Turn the amp OFF and disconnect the USB cable. Restart the amp while holding the CH B and MANUAL buttons. If that fixes it, make sure the USB is not connected to a HUB (or front USB Ports on a Desktop). Check that you have the latest version of L6 Updater. If it fails again, try a different USB Cable. Even if you're using the cable that came with the Cat, defective cables are not unheard of. Max USB Cable Length is 15ft. If it doesn't work, contact support. Quote Link to comment Share on other sites More sharing options...
Guillee Posted April 2, 2024 Author Share Posted April 2, 2024 Thank you very much for your tip, I have tried but Catalyst does not start. Quote Link to comment Share on other sites More sharing options...
jcoll14 Posted April 4, 2024 Share Posted April 4, 2024 On 4/2/2024 at 3:27 PM, Guillee said: Thank you very much for your tip, I have tried but Catalyst does not start. having the same problem, any fix? Quote Link to comment Share on other sites More sharing options...
jiml6 Posted April 11, 2024 Share Posted April 11, 2024 If a factory reset doesn't fix it, open a support ticket. Quote Link to comment Share on other sites More sharing options...
dannygt79 Posted April 17, 2024 Share Posted April 17, 2024 I just had this happen. When you power cycle the amp back on holding A and B, you won't see any lights or anything on the amp. It will still look "dead". It is in bootload mode. Reopen Updater or Line 6 Central. It probably won't see the amp. It will give a message that says something about seeing a "generic USB device, do you want to identify it?". Select "identify". Select the product you need to update and just try the update again. Once the update shows as completed, power cycle at the end (no need to hold anything this time) and you should be good. Quote Link to comment Share on other sites More sharing options...
