medicinewolf99 Posted April 17, 2024 Share Posted April 17, 2024 I have several questions all related to each other. I have a stomp XL and am using the 4 cable method of connecting to my Mesa head. I want to use the original amp sound as I like it and just use the effects part of the stomp(distortion, Wah(I have an expression pedal) delay, chorus are the main ones. 1. How do I chain these in HX edit using the 4CM so I still have the Mesa sound but just with those effects? Where do I put the effects loop in the chain? I see L and R outs as well so I'm just confused on how to chain it together. It seems that when I have the stomp connected through the 4CM it colors the amps sound and I don't get the true amp sound. I do not have any amp or cab models in the chain. 2. If I just want to use the Mesa amp for my distortion and do a lead boost what would be the best stomp pedal for that? 3. Once I have the chain in HX Edit with effects loop in there, DO i need to turn the effects loop on and off and assign it to a switch? If so what does that do exactly? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted April 17, 2024 Share Posted April 17, 2024 4cm: 1) Guitar>HXSXL Input This is where you put the FX you want BEFORE the Mesa Preamp After those FX you place the FX Loop L Block HXSXL SEND (TS cable = Left Send)>Mesa Input Mesa FX Loop Send>HXSXL L/Mono Return This will return the Mesa's Preamp (with the FX assigned before the HXSXL FX Loop Block) to the FX Loop Block After the FX Loop Block is where you put FX like Delay/Reverb that you want between the Mesa Preamp and Poweramp HXSXL L/Mono MAIN Output>Mesa FX Loop Return 2) if you want a CLEAN boost to the overall volume, you can either place a GAIN Block at the END of the chain (before the Output block) or, to conserve a Block, assign a FS to the Output Block Level and set the MIN (Bypass/Controller Assign in HX Edit) to 0db and the MAX to whatever you want (I use +4db). 3) Only if you want to replace the Mesa Preamp with a Helix Amp/Preamp, in which case you place the Helix Amp Block next to the FX Loop Block, assign both to the same FS, and SAVE the preset with the FX Loop ON (the default for the Preset) and the Helix Amp OFF. This will Toggle the FX Loop (ON = Mesa Preamp, Helix Amp=OFF) and the Helix Amp (FX Loop =OFF, Helix Amp=ON). Quote Link to comment Share on other sites More sharing options...
medicinewolf99 Posted April 19, 2024 Author Share Posted April 19, 2024 SO now i have it on a blank preset and still not getting my "true amp sound" its like the distortion isn't coming through and none of my amp controls affect the sound at all. So then I hit the bypass on the line 6 effects unit and still same thing...no true amp sound...and amp controls don't affect the sound including volume and gain....So it must be the way I have everything routed,,,Doesn't seem like how I have everything in HX edit is the issue I have guitar>Stomp input(L Mono) Stomp L Mono output > Amp return stomp L mono return> Amp Send Stomp Stereo Send > AMP input Quote Link to comment Share on other sites More sharing options...
Schmalle Posted April 19, 2024 Share Posted April 19, 2024 On 4/19/2024 at 10:21 PM, medicinewolf99 said: SO now i have it on a blank preset and still not getting my "true amp sound" its like the distortion isn't coming through and none of my amp controls affect the sound at all. So then I hit the bypass on the line 6 effects unit and still same thing...no true amp sound...and amp controls don't affect the sound including volume and gain....So it must be the way I have everything routed,,,Doesn't seem like how I have everything in HX edit is the issue I have guitar>Stomp input(L Mono) Stomp L Mono output > Amp return stomp L mono return> Amp Send Stomp Stereo Send > AMP input You need an FX Loop L block in the path for it to work. Also for unity gain make sure Global Settings -> Ins/Outs -> Input Level, Output Level and Send/Return L are set to Inst. Also crank the VOLUME knob. Quote Link to comment Share on other sites More sharing options...
medicinewolf99 Posted April 19, 2024 Author Share Posted April 19, 2024 So it should go like this? Input>wah> FX Loop L >delay>chorus> Output Quote Link to comment Share on other sites More sharing options...
medicinewolf99 Posted April 20, 2024 Author Share Posted April 20, 2024 yes and im just checking...it seems to be working....and I thought my previous post just confirmed what your diagram depicted...If im still messing up then I guess I suck at following diagrams Quote Link to comment Share on other sites More sharing options...
rd2rk Posted April 20, 2024 Share Posted April 20, 2024 On 4/19/2024 at 10:22 PM, medicinewolf99 said: yes and im just checking...it seems to be working....and I thought my previous post just confirmed what your diagram depicted...If im still messing up then I guess I suck at following diagrams My description and his diagram, plus the descriptions and diagrams in the manual, should be enough. But you say it's working, so ROCK ON! Quote Link to comment Share on other sites More sharing options...
