anfis Posted May 10, 2024 Share Posted May 10, 2024 Hello, I bought the HD Metal pack, I have everything authorized and I see the pack installed both in the licensed manager and in the setup page 12 of the pod. However, I don't see the amplifiers for which I bought the pack. (peavey 5150, Bogner Shiva, JCM800 remastered). If anyone had this same problem I would greatly appreciate the help. Greetings. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted May 11, 2024 Share Posted May 11, 2024 On 5/10/2024 at 6:55 PM, anfis said: I don't see the amplifiers for which I bought the pack. (peavey 5150, Bogner Shiva, JCM800 remastered). You are correct. You don't see those trademarked terms being used. Quote Link to comment Share on other sites More sharing options...
hurghanico Posted May 11, 2024 Share Posted May 11, 2024 On 5/11/2024 at 12:55 AM, anfis said: Hello, I bought the HD Metal pack, I have everything authorized and I see the pack installed both in the licensed manager and in the setup page 12 of the pod. However, I don't see the amplifiers for which I bought the pack. (peavey 5150, Bogner Shiva, JCM800 remastered). If anyone had this same problem I would greatly appreciate the help. Greetings. If you mean that after installing the model pack you don't find any presets already made with the models you just bought, know that you won't find any, it's normal and that's how it works. What happens when you install a model pack is that new models are added to the others that are already in the list of amp models supplied with the device and they are therefore findable and selectable when you edit/create a preset. _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Quote Link to comment Share on other sites More sharing options...
anfis Posted May 11, 2024 Author Share Posted May 11, 2024 Hello, thanks for responding. I'm not talking about presets, I'm talking about emulating amps like the Peavey 5150, Bogner Shiva, etc. Quote Link to comment Share on other sites More sharing options...
anfis Posted May 11, 2024 Author Share Posted May 11, 2024 On 5/11/2024 at 11:05 AM, hurghanico said: If you mean that after installing the model pack you don't find any presets already made with the models you just bought, know that you won't find any, it's normal and that's how it works. What happens when you install a model pack is that new models are added to the others that are already in the list of amp models supplied with the device and they are therefore findable and selectable when you edit/create a preset. _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Hello, thanks for responding. I'm not talking about presets, I'm talking about emulating amps like the Peavey 5150, Bogner Shiva, etc. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted May 11, 2024 Share Posted May 11, 2024 On 5/10/2024 at 6:55 PM, anfis said: I don't see the amplifiers for which I bought the pack. (peavey 5150, Bogner Shiva, JCM800 remastered). On 5/11/2024 at 6:18 PM, anfis said: Hello, thanks for responding. I'm not talking about presets, I'm talking about emulating amps like the Peavey 5150, Bogner Shiva, etc. On 5/10/2024 at 10:18 PM, pianoguyy said: You are correct. You don't see those trademarked terms being used. Quote Link to comment Share on other sites More sharing options...
hurghanico Posted May 11, 2024 Share Posted May 11, 2024 On 5/12/2024 at 12:18 AM, anfis said: Hello, thanks for responding. I'm not talking about presets, I'm talking about emulating amps like the Peavey 5150, Bogner Shiva, etc. Is the device firmware updated to the latest version 2.62? Is the POD HD500X Edit program updated to the latest version 2.27? Both are necessary conditions to be able to use model packs. Furthermore, as suggested by pianoguyy in POD the original names of the modeled amps are replaced by pseudonyms and therefore the Peavey 5150 model is called PV Panama, the Bogner Shiva model is called Mahadeva, and the remastered Marshall JCM800 model (2204) is called Brit 2204. _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Quote Link to comment Share on other sites More sharing options...
