Old Tone Port GX, Can't install Driver
MLO514
Recently found my old Line6 Gearbox Toneport GX. Thought it'd be easy to use. NOOOOOO
After registering an account, registering the device using the serial number, downloading 3 different line6 softwares (license manager, monkey and updater), I still can't install the damn thing.
After already installing it, the Monkey says continuously there's a new version available. It proceeds to re-install the same version, and prompting the same thing over and over again.
Same circular thing for trying to install the driver. It fails to install, an error message appears, prompting to download the installer I already installed....
HELP!!!!
What computer are you using (Mac/PC? OS version?). It’s likely that you are using old technology (Toneport/Gearbox) with a recent OS that is no longer compatible. Check the Downloads area of this website and see if there’s driver version that is compatible with your OS
If not, open a support ticket to see if there’s any way to make them compatible.
