themetallikid Posted June 7 Share Posted June 7 So I tend to assign stomp like changes or auto-engage settings to my expression pedal for various effects. I tend to set my 'turn-on' setting at around 5-7%. However, while playing and I return my pedal to 0%, it will adjust, up a few % points to between 3-7% randomly. I'm assuming 2 things..... 1) the calibration isn't setting the 0% at the correct location (I dont believe this to be the issue as the 100% side of the range is spot on for sure). 2) that the rubber stopper maybe is too thick? would the best remedy be to maybe grind/shave that down a bit to get it to rest lower? Quote Link to comment Share on other sites More sharing options...
theElevators Posted June 7 Share Posted June 7 Is your pedal too loose? Or does the pedal not move itself, while it gets un-calibrated? My Helix LT used to do this where it sometimes would not go past 99%, then 98%. But rebooting it would fix the issue. Quote Link to comment Share on other sites More sharing options...
themetallikid Posted June 7 Author Share Posted June 7 No, its definately not loose enough to fall down if i leave it at 70%, but maybe a bit stiffer would keep it locked down where i step off. Yeah i had the same issue with the LT toe down side where i'd step off it at 100% and it would 'drift' down as far as 85%. so it made it stupidly tough to set the auto-engage thresholds. this isnt doing that, i can see the pedal return to 0, and then move due to the rubber stopper /foot. I used to do toe-down for the 'off' position and switched to heel-down...so I likely just didnt notice it right away (last 5ish years, lol) Quote Link to comment Share on other sites More sharing options...
