Drybonz Posted June 13 Share Posted June 13 Hey guys... just picked up a DMC.Micro Pro to add some buttons on to my HX Stomp. I'm a beginner to Midi and still a bit overwhelmed after looking through the manual. The pedal is set so that it scrolls through my presets out of the box, but my goal is to set it up, at a minimum to scroll through banks instead, and maybe use the hold function to switch between snapshots and stomp. I'm going to be using the web editor. Will this be something I can do using the utility modes in the pedal? Any help setting this up is appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
Schmalle Posted June 13 Share Posted June 13 Hi. The HX Stomp doesn't use MIDI banks. You can only achieve bank switching by setting up some foot switches on the Stomp to do that. You can then emulate pressing those bank foot switches via MIDI [CC #48+x where x is the foot switch number e.g. emulating pressing FS4 is MIDI CC#52]. See HX manual p.60 for what the HX can do MIDI wise and add: CC 72 value 64-127 = next preset, value 0-63 = previous preset. CC 73 toggles between Play and Edit views The DMC manual gives some HX specific suggestion on p. 21. Quote Link to comment Share on other sites More sharing options...
Drybonz Posted June 13 Author Share Posted June 13 Ok, thanks for that... so, by default is the DMC.Micro emulating the FS4 and FS5? Quote Link to comment Share on other sites More sharing options...
Schmalle Posted June 13 Share Posted June 13 How did you read that out of my post? By default seems to use CC 72 value 64-127 = next preset, value 0-63 = previous preset. Quote Link to comment Share on other sites More sharing options...
Drybonz Posted June 13 Author Share Posted June 13 I believe I had FS4 and 5 set to scroll presets, so assumed that might be how it was set up by default. So, I set the buttons to 52 and 53 in the editor on the utility X page and now it controls FS4 and 5 and then I changed those to bank up and down in the HX and it's working. I have bank up and down buttons. Thanks for the help. For the number values, is there a good resource, other than Disaster Area's HX recipes page and the HX manual, to find what numbers to enter for various functions, or do those represent all the possibilities? Quote Link to comment Share on other sites More sharing options...
Schmalle Posted June 13 Share Posted June 13 On 6/13/2024 at 5:54 AM, Drybonz said: I believe I had FS4 and 5 set to scroll presets, so assumed that might be how it was set up by default. So, I set the buttons to 52 and 53 in the editor on the utility X page and now it controls FS4 and 5 and then I changed those to bank up and down in the HX and it's working. I have bank up and down buttons. Thanks for the help. For the number values, is there a good resource, other than Disaster Area's HX recipes page and the HX manual, to find what numbers to enter for various functions, or do those represent all the possibilities? The manual is for firmware 3.0. Since then updates have been made and MIDI functionality has been added. Unfortunately there is no comprehensive document for this AFAIK You can see the firmware changes here. But I think CC#72 and CC#73 are the only relevant additions for you. Quote Link to comment Share on other sites More sharing options...
