markcopeland74 Posted June 16 Share Posted June 16 This is annoying me no end... When using snapshots in stomp mode, is there a way to stop the scribble strip displaying 'Snapshot' with Type, Press and Release underneath and show the name of the snapshot instead after you've stepped on the switch? Put another way, the scribble strip of the last button you switched displays the edit parameters rather than the name of the snapshot or effect until another switch is pressed, which then changes the display of that scribble strip to the edit parameters. If there's no way to prevent this seems like a major oversight as you can't see which snapshot you're going to. This is a major problem when playing live! Quote Link to comment Share on other sites More sharing options...
Schmalle Posted June 16 Share Posted June 16 Maybe for now only use Snapshot Commands to toggle between two snapshots? This way you always know that the foot switch gets you to "the other" snapshot. Generally what you're proposing is a great idea. HX is constantly evolving and I also hope that target snapshot names will show up in the foot switch labels in the a future update Quote Link to comment Share on other sites More sharing options...
markcopeland74 Posted June 16 Author Share Posted June 16 Seems odd that this guy doesn't have this problem- at 2.52 he steps on the switch for a snapshot and when he releases it shows the new target snapshot's name. Quote Link to comment Share on other sites More sharing options...
Schmalle Posted June 16 Share Posted June 16 Please note that the nameless snapshot labels occur when you use Prev or Next. When you use SnapshotX (where X is the target number) then the button is named. Quote Link to comment Share on other sites More sharing options...
markcopeland74 Posted June 16 Author Share Posted June 16 On 6/17/2024 at 8:57 AM, Schmalle said: Please note that the nameless snapshot labels occur when you use Prev or Next. When you use SnapshotX (where X is the target number) then the button is named. Not in my case. Quote Link to comment Share on other sites More sharing options...
markcopeland74 Posted June 16 Author Share Posted June 16 I made a video showing the issue Quote Link to comment Share on other sites More sharing options...
Schmalle Posted June 17 Share Posted June 17 @markcopeland74 Ah, that is an issue that is different from what I thought when I read your previous posts. Apologies. I don't have an HX Effects. Maybe selecting the Stomp is causing this. Experiment with the options in Global Settings -> Switches -> Stomp Select. Quote Link to comment Share on other sites More sharing options...
C4TH Posted June 17 Share Posted June 17 Thread I made about this a while back. 1 Quote Link to comment Share on other sites More sharing options...
markcopeland74 Posted June 17 Author Share Posted June 17 Thanks C4TH! I did a search before posting this thread but for some reason didn't see your one. I read the response from L6 that another user received saying that the issue was because the "global setting MENU > Global Settings > Switches > "Stomp Select" was set to "both"... Mine was actually set to 'press,' which causes the same problem. I've now set it to 'touch' which works as long as you have shoes on! I've had a Helix Floor in the past and found I had to disable touch because it was constantly activating when I didn't want it to. Seems like the lesser of two problems so I'm really happy to have resolved it. Thanks again! 1 1 Quote Link to comment Share on other sites More sharing options...
C4TH Posted July 5 Share Posted July 5 On 6/17/2024 at 8:46 PM, markcopeland74 said: Thanks C4TH! I did a search before posting this thread but for some reason didn't see your one. I read the response from L6 that another user received saying that the issue was because the "global setting MENU > Global Settings > Switches > "Stomp Select" was set to "both"... Mine was actually set to 'press,' which causes the same problem. I've now set it to 'touch' which works as long as you have shoes on! I've had a Helix Floor in the past and found I had to disable touch because it was constantly activating when I didn't want it to. Seems like the lesser of two problems so I'm really happy to have resolved it. Thanks again! Sorry for the late reply. No problem. Quote Link to comment Share on other sites More sharing options...
