Control HX One with HX Stomp
Snys
Hi!
I have the HX One before the HX Stomp in my signal chain.
I want to call up presets in the HX One with the three footswitches on the HX Stomp (in stomp mode).
I can not make it work. I’ve tried via command center on the Stomp but I guess I’m missing something…?
It’s no problem to call up presets with the MC8, but in this case it’s not what I want to do.
Any suggestions?
What YouTube-video could I’ve possibly have missed…?
There’s a section of the HX One manual the describes in detail its midi capabilities. I notice that there’s a setting regarding the preset (PC) commands. You need to make sure the MIDI PC Rx parameter is set to on.
Between them the HX One and HX Stomp MIDI sections of the manuals should clarify things for you.
I’ve read both manuals again and watched a few videos, I think both are set correct.
I’ve managed to call up presets via ”Bank/Prog (Program Change)” in the Command Center.
It calls up the preset, but then I can’t turn it of. I wanna press once to engage the preset, press again and disengage the preset.
Any idea?
