wtcline Posted July 7, 2024 Share Posted July 7, 2024 Hello - am learning Reaper focused on using the DAW to change presets in HX Effects, using Program Change messages. This works within Cubase, no issues. With Reaper, I believe I have set everything up to work. My setup info recognizes HX Effects, and have set it to enable MIDI messages. I have used the Event List editor to add several PC events, with what I believe to be the correct information. Sample: Bank/Program Select dialog box. Bank is empty, Program is empty, MIDI channel is set to 9 (as is the HX Effects unit), Bank MSB/LSB are both at 0. Program Number is on 2, which should bring up my #3 preset. It does not, no change within HX Effects. I set up a sample list of events, asking HX Effects to change to 3 different presets over 9 measures. None of them are working. I have HX Effects set to USB MIDI on, along with the standard MIDI ports also active. Again, Cubase has a similar feature (list Editor) and it works. Clearly I am missing something on the Reaper side. Any ideas what to look for? Thanks, Terry Quote Link to comment Share on other sites More sharing options...
rd2rk Posted July 7, 2024 Share Posted July 7, 2024 Reaper>Options>Preferences>MIDI Devices Make sure the HXS is set as a MIDI Output On the track you're sending MIDI from, ROUTE the Output to the HXS with the proper Channel . HXFX Global MIDI PC Rx ON. Screenshot attached. Quote Link to comment Share on other sites More sharing options...
wtcline Posted July 7, 2024 Author Share Posted July 7, 2024 Thank you - The routing was the key. As a total newby, I didn't know about the routing options. Just figured out how to route a MIDI track to the HX Effects - and by gosh it worked. Thanks again. Quote Link to comment Share on other sites More sharing options...
