tabqwerty2 Posted July 11, 2024 Share Posted July 11, 2024 Attached is the specific pictured gear I'm using. I was doing the four cable method just with the boost and HX Effects together, but I wanted to have the best possible noise suppressor pedal both in front and after the preamp because this amp makes a lot of noise. Quote Link to comment Share on other sites More sharing options...
Schmalle Posted July 12, 2024 Share Posted July 12, 2024 Guitar -> ISP Guitar IN ISP Guitar Out -> Boost IN Boost Out -> HX IN HX Send -> Amp input Amp Send -> ISP Dec IN ISP DEC OUT -> HX Return HX OUT -> Amp Return If you do it like that the ISP is reducing the preamp noise but doesn't affect delay and reverb tails. You might need to put the boost after the HX Send depending on the amount of boost you need. But there is a good chance that you don't need the boost at all because the HX does this very well, too. Quote Link to comment Share on other sites More sharing options...
