Adding an effect into a blank area of the 6 switch looper?
a6strng
Not that I know of, but there's a better way anyway - use command centre to add some of the Looper buttons as footswitches on your normal patch. For almost all my patches, I have Rec/OD, Play/Pause and Undo/Redo as three of the 8 (or 10) stomps. That way, you don't need to go in / out of the looper mode anyway. You don't need to even assign the Looper to a separate stomp if you don't need the other buttons (basically just reverse and 1/2 speed).
This is kind of onerous to set up on every patch - so I recommend you save a template patch with these already in place.
  • Upvote 3
