joeyrex Posted August 12, 2024 Share Posted August 12, 2024 Hi. I have 2 amp modelers, Amplitube and SLT AmpHub. I want to channel them through my Helix LT. The Helix is my only interface to my speakers and computer. I created a preset and used different I/O combinations but no success. Anyone know how to do this? Thanks for responding. Quote Link to comment Share on other sites More sharing options...
datacommando Posted August 13, 2024 Share Posted August 13, 2024 On 8/13/2024 at 12:52 AM, joeyrex said: Anyone know how to do this? Yes, but when seeking assistance from Forum users it's a really good idea to supply as much information as possible regarding the computer and operating system, and DAW, you are using. O.K. Here we go. What you actually mean is, you have three amp modellers - Amplitube, SLT AmpHub, and Helix LT. If you are using your Helix LT as an audio interface, and it is connected via USB to your computer, anything sent out on USB 1&2 back through your LT with it’s input set on “Multi” should come out of the monitors that you have connected without any further processing from the Helix hardware. Consult the Helix LT 3.0 Owner’s Manual > page 69 > USB Audio. Download it here:- https://line6.com/data/6/0a00050e0745666769ce406d6/application/pdf/Helix LT 3.0 Owner's Manual - English .pdf Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
SaschaFranck Posted August 13, 2024 Share Posted August 13, 2024 Just use USB Ins 7/8 (doesn't matter which) as the input for your Amplitube and AmpHub tracks and things should work. In case you haven't changed anything in the LT's global settings, they should instantly be audible through the main outputs. I doubt you'll be too happy, though, as the latency (delay between input and output) on all HX devices is pretty bad (unfortunately), most people notice it instantly. But give it a try anyway. But that's why many people are still either using the HX hardware for monitoring (while recording their DI guitars "silently in the background" through USB 7/8) or using another interface. Fwiw, I would consider purchasing HX Native. As a hardware owner you'll get a nice discount and you'll be able to perfectly duplicate your hardware-monitored LT sounds and go from there, should you want to alter them after the fact. Quote Link to comment Share on other sites More sharing options...
joeyrex Posted August 13, 2024 Author Share Posted August 13, 2024 Thank-you guys. I'll give it a shot and let you know. Quote Link to comment Share on other sites More sharing options...
