Helix LT FX Loops On Wet Effects
thelimey626
Sup y'all. Looking for some help from my fellow experts. I'm currently using my Helix LT for 2 things. 1 is quiet practice with a Mesa Lonestar IR/Model. The other is for live playing, using it as a pedal/FX board in combination with my Mesa amp (I turn off the IR/Cab sims).
When I use it for quiet practice it's easy to setup the wet FX at the tail end of the chain (after the amp and before the cab).
My question is, is there a way to send one path of pedals (wet FX) to an out so I can create an FX loop in my amp. While sending the distortion, compression etc out another output path to line in to my amp.
So to sum it up, 1 signal for my guitar. 1 out for the distortion/compression effects. 1 out for the FX loop of wet effects.
I hope that made sense.
On 8/21/2024 at 1:37 PM, Schmalle said:
If I read your post correctly you want to apply the four cable method (4CM). The manual explains how this is done.
And failing that, there are a thousand youtube videos that describe the 4CM in gory detail.
