cgscotto1 Posted August 27, 2024 Share Posted August 27, 2024 I encountered something I not encountered with any other pedal that is midi capable via 5-pin din or USB. I have the HX One plugged into a USB hub in my rack. I use USB mainly for the librarian function. I also have the pedal connect to other pedal via 5-pin midi cables. All works perfectly, except when I connect the HX One to the computer via USB. Once I make the USB connection, the pedal stops transmitting midi information to pedals down the line. As soon as I disconnect the USB connect, midi cable functionality returns. Is this a bug or a feature? Thanks. Quote Link to comment Share on other sites More sharing options...
silverhead Posted August 28, 2024 Share Posted August 28, 2024 On 8/27/2024 at 3:59 PM, cgscotto1 said: .... I have the HX One plugged into a USB hub in my rack.... That could be the problem. Can you test without using the USB hub? They are not recommended. Quote Link to comment Share on other sites More sharing options...
cgscotto1 Posted August 28, 2024 Author Share Posted August 28, 2024 Well, the hub turned out to be the problem. Plugged the HX One directly into the laptop, opened the librarian, and sent some midi commands from my controller. The HX One passed the information to the next pedal while being also connected via USB. Thanks! I can work around this problem. I like to have all the USB devices in my rack connected to a hub, so I only need a single USB cable to connect them to their various editors. Quote Link to comment Share on other sites More sharing options...
