Problem in pod go with Ducked Delay
albi70
"Pump up"?  What did you pump?  Probably pumped something which you shouldn't have pumped.  Not all things should be pumped.  Best bet would probably to put everything back to the middle, and just switch one thing at a time, that way you'll figure out what ever dial does!  I'm guessing a high treshold or something prevents it from activating because it's too high!
https://helixhelp.com/models?categoryId=5
Quote
Ducked Delay
Available Parameters
  • TempoSync1
  • Note Sync
  • Time
  • Feedback
  • Low Cut
  • High Cut
  • Mix
  • Level
  • Threshold
  • Ducking
  • Dynamic Attack
  • Dynamic Release
  • Dynamic Type
  • Trails
Ok, thanks
