quituri Posted September 21, 2024 Share Posted September 21, 2024 I was just updating to the new firmware of the POD Go and my power chord got disconnected by accident mid-process. Now, I'm trying to turn on the unit and it doesn't go past the welcome screen. The POD Go software doesn't read the unit, even after putting it on update mode. Factory reset mode doesn't work either. It just gets stuck in "Will reset Globals, Presets, IRs..." for ages HELP I need it for a rehearsal tomorrow / gig on Monday Quote Link to comment Share on other sites More sharing options...
silverhead Posted September 22, 2024 Share Posted September 22, 2024 Quote Link to comment Share on other sites More sharing options...
somebodyelse Posted September 23, 2024 Share Posted September 23, 2024 On 9/21/2024 at 11:35 PM, quituri said: I was just updating to the new firmware of the POD Go and my power chord got disconnected by accident mid-process. Now, I'm trying to turn on the unit and it doesn't go past the welcome screen. The POD Go software doesn't read the unit, even after putting it on update mode. Factory reset mode doesn't work either. It just gets stuck in "Will reset Globals, Presets, IRs..." for ages HELP I need it for a rehearsal tomorrow / gig on Monday This will fix it - Download the latest versions of the POD Go firmware, Line 6 Updater and POD Go Edit. Start your POD Go whilst holding down the 'Page Right' button. Don't worry about the grey screen. Make sure your computer is not running ANY background music streaming crap like Spotify. Make sure your USB cable is in good nick. Plug the POD Go to your computer. Start Line 6 Updater in Offline Mode'. Select POD Go, select 'Update from file' and try re-installing the v2.0 firmware that you downloaded. If it fails to install, download any previous firmware version and repeat the above. When that installs successfully, close the updater, Switch off the POD Go and do the 'Factory reset' startup procedure. Plug the POD Go in, start up POD Go Edit - NOT the Line 6 Updater. FOLLOW THE INSTRUCTIONS. The update will take about half an hour. Let us know how you get on. Quote Link to comment Share on other sites More sharing options...
