Kowtoww Posted October 18 Share Posted October 18 Just wondering any Helix LT owners know if there is an amp out source like there is on the POD GO with the option of bypassing the Cab/IR so you can use your amp/cab and FOH at the same time using the true sound of your cab? Quote Link to comment Share on other sites More sharing options...
silverhead Posted October 18 Share Posted October 18 You can use a Send block at any chosen location in the signal chain of your LT preset. Connect the corresponding physical outputs to FOH and your amp respectively and set the Output Levels to match the receiving device. 1 Quote Link to comment Share on other sites More sharing options...
somebodyelse Posted October 19 Share Posted October 19 On 10/18/2024 at 7:40 AM, Kowtoww said: Just wondering any Helix LT owners know if there is an amp out source like there is on the POD GO with the option of bypassing the Cab/IR so you can use your amp/cab and FOH at the same time using the true sound of your cab? Oh boy... I have a Helix Floor and a POD Go, and I'm intimately familiar with the LT's manual. The LT can do everything (and much, much more) that the POD Go can do without breaking a sweat. If you're mulling over whether it'd be worth getting a Helix LT, at the price they're selling them in the UK at the moment, it's a 'no brainer'. It's by far the 'best value for the money' product Line 6 currently sells. Quote Link to comment Share on other sites More sharing options...
