Helix Edit under Linux (Arch)
M4R71N88
Hello, I searched the internet for help on using Helix Edit on Linux. I have no problem running the native Helix plugin under Arch Linux using Yabridge, which works flawlessly. However, I still need to perform firmware updates for my Helix Floor and enjoy the convenience of editing presets using Helix Edit.
Since I couldn’t find anything online, I decided to come up with a solution myself. I can confirm that I was successful in running Helix Edit on Linux. Below are the steps to achieve it:
1. Install Wine and Required Dependencies
Make sure you have Wine and its required dependencies installed.
-  sudo pacman -S wine wine-mono wine-gecko winetricks
-  yay -S wineasio
-     register the ASIO driver within Wine:  wine regsvr32 wineasio.dll
2. Install Line 6 Helix Edit in Wine
  1. Download the Helix Edit installer
  2. Run the installer using Wine: wine path/to/helixedit_installer.exe
  3. Follow the installation prompts.
3. Workaround for USB Connection Using USB Passthrough with VirtualHere (USB Sharing):
Since Wine doesn't natively support USB devices like the Line 6 Helix, a solution is to use a USB-over-network tool like VirtualHere, which allows USB devices to be shared with Wine over a virtual connection.
Steps for VirtualHere:
Installation:
-     yay -S virtualhere-server-bin
-     yay -S virtualhere-client
  1. Run the VirtualHere USB Server on your Linux machine:
    sudo ./vhuitarm -b
    Or use the appropriate version for your machine.
  2. Run the VirtualHere Client in Wine:
    wine path/to/virtualhere_client.exe
  3. The USB device (Helix) will now appear in VirtualHere, and you can "attach" it inside Wine
  (Alternative to VirtualHere) Configuring USB Device Access via usbip:
For a more manual solution, you can use USB/IP to share your USB device and try to access it from Wine.
  1. Install usbip:
    sudo pacman -S usbip
  2. Load the necessary kernel modules:
    sudo modprobe vhci-hcd
  3. Find the USB device:
    usbip list -l
  4. Bind the USB device (replace <busid> with the correct ID from the previous command):
    sudo usbip bind -b <busid>
    The device should now be accessible within Wine.
  • Like 2
