mandiboy Posted Friday at 08:46 AM Share Posted Friday at 08:46 AM is there a place to download the older fiormware for catalyst 100?- the new presets after update and reset suck and I cant access the originals or finf rthem anywhere Quote Link to comment Share on other sites More sharing options...
rd2rk Posted Friday at 03:22 PM Share Posted Friday at 03:22 PM Connect your Cat to your computer. Run the Line6 Updater. If you don’t have it, go to Line6.com/downloads to get it. Select your Cat. Select the version to install. Follow any directions that appear. READ THE MANUAL! It can be found at Line6.com/Support. Get both the original and the new version. Back up your stock presets INDIVIDUALLY to your computer. Now Re-run and reinstall the latest FW. You can now restore any of the magical 1st version presets, WITHOUT losing all of the great features of the latest version. A bit of advice. READ THE MANUAL and learn how to use your Catalyst. Presets are for newbs to LEARN with. You’ll thank me later. Quote Link to comment Share on other sites More sharing options...
mandiboy Posted Friday at 03:57 PM Author Share Posted Friday at 03:57 PM On 10/25/2024 at 11:22 AM, rd2rk said: Connect your Cat to your computer. Run the Line6 Updater. If you don’t have it, go to Line6.com/downloads to get it. Select your Cat. Select the version to install. Follow any directions that appear. READ THE MANUAL! It can be found at Line6.com/Support. Get both the original and the new version. Back up your stock presets INDIVIDUALLY to your computer. Now Re-run and reinstall the latest FW. You can now restore any of the magical 1st version presets, WITHOUT losing all of the great features of the latest version. A bit of advice. READ THE MANUAL and learn how to use your Catalyst. Presets are for newbs to LEARN with. You’ll thank me later. i know most suck but there were a couple originals that were good starting points Quote Link to comment Share on other sites More sharing options...
