Volume level difference between Clarity and Archetype Clean
EddieTheTrooper
Is it normal that even on the same settings this two amps models differ so much in volume levels? I just made my clean tone using Clarity amp and just wanted to compare it with Archetype. I changed only amp model didn't touch anything else only amp group. The difference is huge: Clarity is much louder than Archetype, why?
Yes it’s normal. Real, physical amps also demonstrate this difference. Different types of amps respond differently to the ‘same’ settings. Some amps,are simply louder or quieter than others. There’s no industry standard around this. The two amp models you mention are very different: one is a Line 6 Original and the other is modeled on a physical amp. No reason they should behave similarly. Some amp designers and guitar players Iike it to sound like it’s turned up to 11.
