FS1 Preset Bank Up Bug?
txflood
I have an original Cat 60 that has the CX upgrade installed. I wanted to do some comparisons between amp models while playing so I decided to try to take advantage of the new footswitch functionality that the upgrade provided.
I have set FS1 to Preset Bank Up and FS2 to Channel A/B Select. The switches work as advertised and allow me to quickly switch between banks and channels.
The issue that I am seeing though is that when I power the Catalyst off and turn it back on again later, the bank increments and changes. For example if I have the amp on bank 1 when I turn it off, the next time I power it back on again it automatically moves to bank 2 even though I didn't touch anything other than the power switch.
I also for debugging purposes tried the reverse where I made FS1 the A/B select and FS2 the bank up. It still gives me the same result when powering off and back on again.
Has anyone else tried the Preset Bank Up footswitch setting and seen any problems like this?
