cmscss Posted January 26, 2025 Share Posted January 26, 2025 Hi There, Can a foot switch be used to switch path B (wet effects) between sends and main outs? And if so, how do you set that up? Sorry if that's easy, any pointers in the right direction much appreciated. Cheers, Ben Quote Link to comment Share on other sites More sharing options...
rd2rk Posted January 26, 2025 Share Posted January 26, 2025 Place the SEND Block at the end of Path B (before the MIX Block in Path A) and set the DRY THRU to -120db. When the SEND Block is BYPASSED the signal goes through to the MIX Block on Path A and out through the MAIN Outs. When ACTIVE the DRY THRU -120db setting prevents the signal from passing through to the MIX Block/MAIN Out. 1 1 Quote Link to comment Share on other sites More sharing options...
cmscss Posted January 26, 2025 Author Share Posted January 26, 2025 @rd2rk Amazing, thank you. Will test this out. Cheers, Ben Quote Link to comment Share on other sites More sharing options...
