rwinking Posted February 22, 2025 Share Posted February 22, 2025 Trying to get my head around this thing. What I am attempting to do is use my Quad Cortex for both an acoustic and electric rig. So I have a Grace Felix plugged into input number 1 for acoustic and then my QC into input number 2 for electric. I noticed that when I have different things in each input, it only comes out one speaker. It's like each input is assigned to one or the other speaker. If I plug the QC into input I and the Felix into input 2 my electric guitar from the QC only comes out one side. If I unplug the Felix from input 2 input one gets both speakers. Is this normal? More importantly, is there a way from me to do what I am attempting..... have whatever I have plugged into one input or the other come out both speakers? I also have a 112+ but have not tried it on there since it only has one speaker anyway. I hope I am explaining myself on this. It is kind of confusing to me... Quote Link to comment Share on other sites More sharing options...
rd2rk Posted February 23, 2025 Share Posted February 23, 2025 That does appear to be the way that it works. The fix (I have a Helix) is to connect the Felix to a Return and place the Return right before the Output. If you can do something similar with your QC you should be good. Otherwise you'll need to use a mixer. Quote Link to comment Share on other sites More sharing options...
rwinking Posted February 23, 2025 Author Share Posted February 23, 2025 Thanks a Iot! This is putting me closer for sure. I also have a Helix and Stomp XL. I'm still not sure how this would work. Do I put an FX return block on the Helix right before I assign an output? I am pretty sure if I can do this on the Helix, I can then adapt it to the QC . It's interesting that I tried this with input 1 & 2 on my Powercab 112+ and there is no issue. It must have something to do with the stereo capability of the 212+? rick Quote Link to comment Share on other sites More sharing options...
rd2rk Posted February 23, 2025 Share Posted February 23, 2025 Place the Return Block last in the signal chain, just before the Output Block. For the HXS/HXSXL, since FX Blocks are more limited, if you're not using the FX Loops (nothing is free!), set the RETURN TYPE to AUX and connect the Felix to the L/Mono Return. Yeah, the PC112+ has only one speaker, so... Quote Link to comment Share on other sites More sharing options...
