How to scroll to Snapshots 5-8 in Preset/Snap mode?
Prsgibson
I would like to have Preset/Snap mode but it only shows the first 4 snapshots. How so you scroll to see the last 4 Snaphots in this mode? Bank up and down on the left is not doing it.
Thanks
Thanks
If you decide to allocate the foot switches to Preset/Snap, then you will have automatically limited the access to the first 4 Snapshots in that particular configuration.
The Presets are available and can be used directly and also scrolled through using FS1&7 for PRESET UP/DOWN functions.
Essentially the only way to access any Snapshot from 5-8 is to press both FS1&7 together which should then display all 8 Snapshots. If you then press for example Snapshot 7 that will be displayed in the little Camera Icon in the top right of the screen, and the foot switch layout  will return to 4 Presets on the top row and 4 Snaps on the lower switches.
If this is too much tap dancing, you may want to consider creating Stackable Snapshots by using the Command Center.
Check out this video from Steve Sterlacci.
Hope this helps makes sense.
