vstrattomusic Posted April 19, 2025 Share Posted April 19, 2025 I wonder if they still replace these units. I bought mine in Jan 2018 and haven't used the pedal much. Decided to use it yesterday modulating some effects and it was broken. Already opened a support ticket. Also since I don't have any warranty after 7 years I've decided to open the Helix LT and take a look at what's happening inside. It seems to be the same problem that people were having years ago. I've taken a few pictures. The other side Quote Link to comment Share on other sites More sharing options...
theElevators Posted April 21, 2025 Share Posted April 21, 2025 I would just take off the pedal, and get a small external one and velcro it to the body. 1 Quote Link to comment Share on other sites More sharing options...
Stephanie15W Posted April 22, 2025 Share Posted April 22, 2025 Hello! Given your Helix LT was purchased in January 2018, a free replacement after seven years is unlikely, as the standard warranty is much shorter. However, reports from that era suggest Line 6 may have offered replacements for faulty expression pedals due to a known early issue. Your best course of action is to pursue your My Acuvue Rewards open support ticket, mentioning this historical context. Be prepared that repair options, either through Line 6 (likely at cost), third-party services, or DIY fixes, are more probable outcomes at this stage. Quote Link to comment Share on other sites More sharing options...
vstrattomusic Posted April 22, 2025 Author Share Posted April 22, 2025 On 4/21/2025 at 6:15 PM, theElevators said: I would just take off the pedal, and get a small external one and velcro it to the body. Velcro?? Why not weld it to the Helix LT, then glue the Exp 1 input with silicone? Maybe I could saw off the whole pedal area with an angle grinder, then weld it together with the end part, making a one-off, ultra unique, pedal-less Helix LT. Minds will be blown when people see that lollipop Quote Link to comment Share on other sites More sharing options...
vstrattomusic Posted April 22, 2025 Author Share Posted April 22, 2025 On 4/22/2025 at 7:24 AM, Stephanie15W said: Hello! Given your Helix LT was purchased in January 2018, a free replacement after seven years is unlikely, as the standard warranty is much shorter. However, reports from that era suggest Line 6 may have offered replacements for faulty expression pedals due to a known early issue. Your best course of action is to pursue your open support ticket, mentioning this historical context. Be prepared that repair options, either through Line 6 (likely at cost), third-party services, or DIY fixes, are more probable outcomes at this stage. Are you an AI? Quote Link to comment Share on other sites More sharing options...
theElevators Posted April 22, 2025 Share Posted April 22, 2025 On 4/22/2025 at 6:56 AM, vstrattomusic said: Velcro?? Why not weld it to the Helix LT, then glue the Exp 1 input with silicone? Maybe I could saw off the whole pedal area with an angle grinder, then weld it together with the end part, making a one-off, ultra unique, pedal-less Helix LT. Minds will be blown when people see that lollipop yeah! Gorilla Glue is so strong. My previous rig consisted of MS-3 little processor, and I glued 2 side buttons to it. Toured with that extensively :). But with Velcro, you can take it off, in case then new pedal breaks... And lighten up. Why are you so mad. LT is a flimsier version of the Helix. Just giving you some options. If my LT pedal broke, I'd do the same as I suggested. Quote Link to comment Share on other sites More sharing options...
vstrattomusic Posted April 22, 2025 Author Share Posted April 22, 2025 On 4/22/2025 at 4:44 PM, theElevators said: yeah! Gorilla Glue is so strong. My previous rig consisted of MS-3 little processor, and I glued 2 side buttons to it. Toured with that extensively :). But with Velcro, you can take it off, in case then new pedal breaks... And lighten up. Why are you so mad. LT is a flimsier version of the Helix. Just giving you some options. If my LT pedal broke, I'd do the same as I suggested. I'm not mad, just joking around. You know I guess while I'm at it I could drill a few holes in the chassis and attach a fan for better ventilation. Connect it to whatever powers the pedal since that no longer works. Or if we get really DIY here, I could cut a square around the pedal area, fill it with little tiles, repurpose one of the inputs and build a little fountain so my cat can drink water from it while I play the guitar. 1 Quote Link to comment Share on other sites More sharing options...
theElevators Posted April 22, 2025 Share Posted April 22, 2025 On 4/22/2025 at 1:53 PM, vstrattomusic said: I'm not mad, just joking around. You know I guess while I'm at it I could drill a few holes in the chassis and attach a fan for better ventilation. Connect it to whatever powers the pedal since that no longer works. Or if we get really DIY here, I could cut a square around the pedal area, fill it with little tiles, repurpose one of the inputs and build a little fountain so my cat can drink water from it while I play the guitar. I'd just add a urinal to it. Sometimes you really gotta go. And a smoke machine. 1 Quote Link to comment Share on other sites More sharing options...
