gpicard5 Posted May 6, 2025 Share Posted May 6, 2025 So I've been using the HX Stomp in my Bass Rig for about a few months. I have the latest firmware loaded and it has worked great. However, the last 2 gigs I've had this issue where I'm playing and then randomly I notice that I'm on a completely different preset. For context: 1. I'm in Stomp Mode and have the 3 FS's set to control different effects. 2. I know I didn't accidentally hit and FS's because 99% of the time I am not switching effects on/off. The only really common thing to the gigs where it happened was that I was relatively close to the subon my side (about 5' away) and the gigs were in daylight outside. Anyone else have this issue? Any ideas on why it happened? How to fix it? Quote Link to comment Share on other sites More sharing options...
Schmalle Posted May 6, 2025 Share Posted May 6, 2025 Make sure you haven't accidently set up a footswitch to change the preset in Command Center. Quote Link to comment Share on other sites More sharing options...
gpicard5 Posted May 12, 2025 Author Share Posted May 12, 2025 So last week I went through ALL settings to ensure that I hadn't inadvertently set anything that could be causing this. I found nothing that would be casuing the described behavior. This past weekend I played 2 gigs and sure enough, same issues. Halfway through one set I looked down and saw that the presets menu was up on screen waiting for me to select one. A different time I looked down and saw that my presets had changed from Preset 001 to 002. The unit is not in a place where someone (band member or otherwise) could have come in contact with it. At this point I am thinking that possibly vibration from the house subs may be causing this?? Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 12, 2025 Share Posted May 12, 2025 Is it possible that you are mistakenly pressing the wrong footswitch, or two footswitches at once, when this happens? Quote Link to comment Share on other sites More sharing options...
gpicard5 Posted May 14, 2025 Author Share Posted May 14, 2025 On 5/12/2025 at 7:12 AM, silverhead said: Is it possible that you are mistakenly pressing the wrong footswitch, or two footswitches at once, when this happens? Nope. Basically I am using the HX Stomp setup with the following blocks: 1. Retro Reel for mild saturation (Always on and no FS assigned) 2. FX Send and Return Block (Always on and no FS assigned) this allows me to have 2 dirt pedals in the loop and blend them with the clean. I use the individual FS's on these dirt boxes. 3. Phaser (Assigned to FS2 and only used for 2 songs) 4. Chorus (Assigned to FS3 and only used for 3 songs) 5. Regal DI (Always On and no FS assigned) The issue I am having frequently occurs mid set / mid song and during songs where I haven't used any of the HX's FS's. Quote Link to comment Share on other sites More sharing options...
gpicard5 Posted May 14, 2025 Author Share Posted May 14, 2025 Oh and I should mention that I have a Hotone Ampero+ Footswitch connected and set for Preset bank switching (FS 1 > Prev and FS2 > Next) However, I have tried disconnecting the unit and it has still happened. Quote Link to comment Share on other sites More sharing options...
