Using Audacity, then Reaper to record Pod Go
Eggzin
I'm using a Windows 10 laptop and the latest version of Audacity software.  I have a stereo backing track imported to Audacity, and I'm hoping to record my practice using the Pod Go USB inputs and outputs.  I have two issues that may be linked.
The first is that, although Audacity shows the PG in both the recording device dropdown menu as well as the output device dropdown menu and I've successfully recorded to a track, I don't see anywhere where I can specify which of the 4 USB channels of the PG I can route to either the input or output in Audacity depending on what I want.
The Pod Go manual shows a routing diagram using those 4 channels in different ways for different purposes, but I don't see where I can make those assignments in either Audacity or Pod Go.  Is this because I need to install the Line 6 ASIO driver in my laptop or, maybe, Audacity just can't do that at all?
Which brings me to the second issue.  My recorded track's level is too low--somewhere between -18 and -12 db.  I have the recording slider maxed out in Audacity.  I was looking for a way raise the output level of the PG without blowing my eardrums when monitoring via the PG.  I thought there may be an adjustment in PG where I can raise the USB output without raising the volume of the speakers connected to the PG.  Would this be possible if I installed the Line 6 ASIO driver into my laptop?
Any help would be very appreciated!
Paul
On 5/28/2025 at 3:46 PM, Eggzin said:
...  Is this because I need to install the Line 6 ASIO driver in my laptop or, maybe, Audacity just can't do that at all?
Yes, you need to install the Line 6 ASIO driver for the POD Go.
I responded to this a couple of days ago, but I may have not been signed in.
I responded to thank you for the answer.  I'm going to load the driver later today and I'll let you know how it goes.
Thanks,
Paul
Silverhead,
I downloaded this driver from Line 6 this morning and installed.   From the list, it looked like the only ASIO choice from the Pod Go driver download page.  I still can't get Audacity to recognize all four channels from Pod Go.  Was this the correct driver?
Line 6 ASIO Driver support for Core Isolation Memory Integrity
I'm on the latest version of Audacity, and I'm running Windows 10 on a very robust laptop.  I followed all instructions when I ran the driver installer.
Any other thoughts?
I appreciate your time Silverhead.  Yea, I've spent the last 2 weekends googling, reading the Audacity manual--which doesn't support ASIO natively, I've looked all throughout the programs and the internet.  My last attempt was to reach out here.
I think I'm going to forget about Audacity and move to Reaper at this point.  Again, I appreciate your effort.
I think moving to Reaper is a good idea. Over the years I've heard many users report problems using Audacity with Line 6 devices. It's usually related to their use of a non-compliant pseudo-ASIO driver called ASIO4ALL. Like you I believe the issue is Audacity's non-support of ASIO natively.
Siverhead, well, I installed Reaper and I'm having the the same problem as with Audacity.
In another line 6 post I saw that you and Phil M said, all the needed USB ASIO drivers are inside Pod Go Edit.  I already had PG Edit installed before I even started troubleshooting the problem--Reaper still didn't recognize all PG's channels.  Since then, I've downloaded and installed two separate drivers from the Line 6 website to no avail.  I'm pulling my hair out...
So this was the process I followed:
In Reaper, I open preferences > Audio device settings, and select ASIO.  Under ASIO Driver, it shows ASIO Pod Go, but in the next fields, under Enable Inputs and Output Range, the dropdown's show nothing--just a blank page.  Nor can I open the ASIO Configuration button close to the bottom of the page.
I have already downloaded and installed two drivers from the Line 6 Pod Go software downloads page.  Neither of them solved the issue.
The first was “Line 6 POD Go Driver2_5”.  The second was “ Line 6 WinUsb”.
Do you think it's worth uninstalling Pod Go Edit and then re-loading, or would that be a waste of time?  Anything else you can suggest?
Paul
Quote
AI answer, (which could or could not be hallucinated...)
Quote
When using the Line 6 Pod Go as an audio interface with Audacity, you may notice that while the Pod Go technically supports four USB audio channels—two for the processed (amp/effects) signal and two for the unprocessed (dry DI) guitar signal—Audacity itself will typically only display and allow selection of stereo (two-channel) recording, not four discrete channels
Most DAWs (like Reaper or Cubase) can access all four channels, letting you record both the processed and DI signals separately
. However, Audacity is limited by its lack of native ASIO driver support, which is required to access more than two channels from many audio interfaces, including the Pod Go. As a result, in Audacity, you will generally only see and be able to record two channels at a time—either a stereo mix or a single mono channel—rather than four independent tracks
Summary:
  • Pod Go provides four USB audio channels (2 processed, 2 DI)
  • Audacity will usually only show two channels (stereo or mono), not four, due to driver limitations
  • To record all four channels simultaneously, use a DAW with full ASIO support (like Reaper, Cubase, etc.), not Audacity
If you need to capture both the processed and DI signals from the Pod Go, consider using a different DAW or look into workarounds for ASIO support in Audacity, though these can be complex and are not officially supported.
But if it's not working with Reaper either, from AI response, there should be a native Reaper ASIO driver that you should be able to use for the 4 channels?
In other words:  Don't use the Line6 Pod Go Asio driver, but instead using the Reaper native ASIO driver should work.
[edit]  It was all hallucinated AI garbage.  See guide below!!
Thanks for your suggestion.  From recent reading on the net, Pod Go is supposed to contain the drivers that Reaper needs to see the four channels.  I can try a search for Reaper usb drivers, but I've been down so many rabbit holes so far...   :>)
On 6/1/2025 at 11:25 AM, Eggzin said:
….  From recent reading on the net, Pod Go is supposed to contain the drivers that Reaper needs to see the four channels…
That’s correct. The proper driver is part of the POD Go Edit download package. After downloading, run he installer and select to install all components. I don’t think Reaper provides usb drivers because they apply to hardware devices. A windows system will provide generic usb drivers for its hardware but an audio interface device like the POD Go typically provides its own unique driver. I believe a purely software product like Reaper uses the host hardware drivers.
Try downloading and installing POD Go Edit again.
What do you mean USB drivers?  Pretty sure you mean Asio drivers instead.
There was some hallucination in that AI response as is appears that Reaper does not have its own native Asio drivers:
Quote
Reaper does not come with native ASIO drivers built into the software itself. Instead, it relies on ASIO drivers provided by your audio hardware manufacturer or third-party ASIO drivers like ASIO4ALL for generic soundcards.
Explanation:
  •  ASIO Drivers Are Hardware-Specific: Most professional audio interfaces come with their own dedicated ASIO drivers developed by the hardware manufacturer. These native ASIO drivers are optimized for low latency and stable performance with that specific device. If you have such an interface, you should use its native ASIO driver in Reaper for the best experience2.
  • Reaper Does Not Include Its Own ASIO Driver: Reaper does not include a built-in ASIO driver. If your audio device does not have a native ASIO driver, you can use ASIO4ALL, which is a generic ASIO "wrapper" that enables ASIO functionality on standard Windows soundcards by bypassing some of the Windows audio layers123.
  •  ASIO4ALL as a Workaround: ASIO4ALL is commonly recommended for users who do not have an audio interface with native ASIO drivers. It is a free, third-party driver that allows Reaper to use ASIO on devices that only have standard Windows drivers. However, it is not a true native ASIO driver but a compatibility layer128.
  • Alternatives to ASIO: On Windows, Reaper also supports other audio systems like WASAPI and DirectSound. WASAPI has improved over the years and can sometimes outperform ASIO4ALL in latency and stability, but ASIO remains the preferred choice for audio production due to its low latency12.
Summary
  • Reaper itself does not come with native ASIO drivers.
  • Use native ASIO drivers provided by your audio interface manufacturer if available.
  • If no native ASIO driver is available, use ASIO4ALL as a generic ASIO driver.
  • WASAPI is an alternative audio system supported by Reaper on Windows.
This means to use ASIO in Reaper, you need either a hardware device with its own ASIO driver or install ASIO4ALL for generic devices
The important part I thought for the previous AI answer was this: "However, Audacity is limited by its lack of native ASIO driver support, which is required to access more than two channels from many audio interfaces, including the Pod Go. As a result, in Audacity, you will generally only see and be able to record two channels at a time—either a stereo mix or a single mono channel—rather than four independent tracks".
But it turns out the native Reaper ASIO drivers were AI hallucinations, likely not an Asio driver issues.
Just found this guide, watching it; might just be a settings/configuration issue, see here!  (make sure you select the same channel # as he does, and while AI said that it wouldn't work for Audacity, maybe should work too with the right channels selected?  No reasons it shouldn't if it isn't a driver issue...!)
Yes, I meant ASIO drivers.
Do I need to uninstall Pod Go Edit first, before installing again?
Thanks for the help with this!
Not necessary in my experience. If something fails the first time you should do this on the next attempt.
I went ahead and uninstalled Pod Go Edit, and then re-installed.  Still no joy, Reaper's still not seeing the 4 channels.
I then went into my Device Manager on my computer. I saw an option to "show hidden files". When I clicked on it, suddenly 4 "Digital Audio Interface (Line 6 Pod Go)" and 4 "Speakers (Line 6 Pod Go)" showed up. The problem is that 3 of them, in each catagory, were greyed out.  Only one of each is not greyed out.
I double clicked on one of the greyed out Interface icons to get to "properties" and the Device status says "Currently, this hardware device is not connected to the computer (Code 45)".
I thought this added info might help you to help me :>)
Anybody have any thoughts?
Did you check the guide I posted?  Guessing you don't have the same options available he does?
For channel 3/4 should be normal, as you likely don't have a stereo guitar.
Thank you for the follow up.  I had seen that video already, before you posted it--it actually was the best of all the videos I've watched, working through this.
But, no, I don't have the same options as he did.
One thing that caught my ear though, is that at 18 seconds in, he says "you want to install 2 things from the Line 6 website.  ...the Line 6 Pod Go Edit software and the Line 6 Pod Go drivers".
What is he talking about?!  According to several Line 6 Experts here in this forum all that's needed is the Pod Go Edit software because everything you'll need is in that software.  What additional "drivers" are needed?  Besides which, I've already tried to add several drivers from that download page with PG Edit already installed, to no avail.
Do you have any idea what he's talking about when he says two things?
Yes, the POD GO Edit download package includes the POD Go Edit program itself as well as the required drivers. But they are separate things. What you download is an installation package. When you run the installer you have an option to deselect certain components such as a driver. It’s not wise to do so, but the program and the driver are two different things. I expect that’s what he is referring to.
This doesn’t address your issue. You seem to have all required components installed. At this point I suggest you open a support ticket.
Thanks for the clarification Silverhead.  This is tough stuff to handle in a thread type environment, so every nuance is important.
I did open a ticket on Sunday, and heard back on Monday and he (Josh) and I had several exchanges, but ultimately he couldn't help.  He suggested I call support.  That'll make it difficult because of the limitations, time-wise, that support is available and my work schedule.
Just as a matter of interest, I had some thoughts.  I realized later, after un-installing Edit, then re-running the Edit .exe, that some of the drivers were not removed during the un-install.  I looked at the "details" of the installation process, and saw that the re-installation skipped installing new drivers because they were already existing in the Device Manager from previous installs.
So, while I look for a opportunity to phone Line 6, I may delete by hand, any Line 6 drivers that show up in the device manager, and try re-installing Pod Go Edit again.
Paul
That’s a good idea. Make sure you restart your computer after uninstalling. If that doesn’t work then it’s a good idea to phone Line 6 Support and ask for specific procedures to completely uninstall Line 6 stuff manually. Then start fresh.
I commend your patience and perseverance. This will eventually get resolved!
Wow Silverhead, I'd have completely missed doing this!  Thanks--you've been a great help.
It looks like I'll have a little time tomorrow morning (EST) to try this.
Another procedural consideration….. Frankly I’m not sure whether this matters at all but it’s the way I would do it anyway.
You haven’t mentioned whether you have any other Line 6 products with installed software. If so I would recommend you also uninstall/reinstall their associated programs and drivers. Uninstall in reverse order of installation time; begin with the POD Go stuff and then proceed backwards in time. When reinstalling, do the reverse; start with the oldest stuff and finish with the POD Go.
Pod Go is the only Line 6 product I have, so I'm okay there.  (Did have a Pod 2.0 decades ago.)  :>)
After I posted to you this morning, I did some more google searching and came across this.  It's from a guy on the Cakewalk forum who was having the same trouble I've had. This was suggested to him by another member:
https://discuss.cakewalk.com/topic/84097-sonar-doesnt-recognize-line-6-pod-go-solved
"I suggest you search your registry for HKEY_LOCAL_MACHINE\SOFTWARE\ASIO to see what other ASIO drivers are installed in that folder and delete them.
You can search the Internet for HKEY_LOCAL_MACHINE\SOFTWARE\ASIO and you will find many examples of people solving ASIO problems by deleting unneeded ASIO drivers from that folder."
I'll likely do the same myself--delete Pod Go asio drivers in the registry, make sure I delete drivers in the Device Manager, even un-install PG Edit in the Windows Control Panel >Programs and Features, restart laptop, then install PG Edit again, fresh.  Josh Steck at Line 6 support did mention the registry in his initial reply to me.
Just an update.
I uninstalled everything Line 6 related on my laptop this morning and did a fresh install of Pod Go Edit.  No success, same as before.
Then I tried my other laptop, with the same Windows 10 OS.  I already had PG Edit installed, so I installed Reaper.  And lo and be-freaking-hold, Reaper recognized all asio inputs and outputs.
So there's something about my first laptop (which is what I use for music stuff), which doesn't allow the linkage.  Still plan to phone Line 6 support when they open later today.
Thanks for the update. Very interesting. I suspect there's some sort of driver conflict on your music laptop. In my experience the most likely suspect is the non-ASIO-compliant ASIO4ALL driver which seems to be the Audacity default. If you want to test this uninstall ASIO4ALL and reboot your computer.
Thanks Silverhead.  ASIO4All is definitly not on the computer.  In fact, I deleted all drivers in the registry via this path  HKEY_LOCAL_MACHINE\SOFTWARE\ASIO, and in the device manager.  There wasn't anything left on my computer, music related, when I was done uninstalling and deleting.
I'm off to phone support.  I'll report back.
Update:
I spoke with Line 6 support yesterday for an hour and forty-five minutes!  He had never seen this issue.  We went through everything, a lot of which I'd already tried.  I learned a lot working with him.  At the end though, still had the same issue.
At his suggestion, I did a reset of the Windows OS.  I haven't had a chance yet to reinstall Reaper and Pod Go.  I'll do that tomorrow, test, and report back.
Paul
Update:
Well, I installed Reaper and Pod Go on this, now, clean Windows 10 OS, and I still have the same issue.
As I mentioned, I have two laptops, both running OS 10.  My music laptop is an Asus, the other is a Lenovo.  On the Lenovo, Pod Go and Reaper work together seemlessly.  Not so on the Asus.
This morning, I went into the registry of both machines to compare them--HKEY Local Machine\Software.  There are definitly missing items in the Asus that are present in the Lenovo.  I made a list of the differences, and now have some Google searching to do.
Before I do that, I'm going to uninstall the native sound card and drivers (Conexant SmartAudio) in the Asus.  Then I'll uninstall PG Edit and reinstall to see if there is/was a conflict with drivers.
I'll report back.
  • Eggzin changed the title to Using Audacity, then Reaper to record Pod Go
