zenny75kler Posted June 5, 2025 Share Posted June 5, 2025 You've observed that after manually changing presets, your delay note setting occasionally, but not always, reverts to "Sync - Whole" even though your intended setting is "1/4 Sync." This seems to be an intermittent issue that doesn't occur with every preset change. You haven't used a footswitch recently, so you can't confirm if the bug also manifests through that method. This inconsistency in behavior suggests a software glitch rather than a user error. It would be beneficial to determine if other users are experiencing similar discrepancies. mybkexperience Quote Link to comment Share on other sites More sharing options...
rd2rk Posted June 5, 2025 Share Posted June 5, 2025 This has been noted by someone else. You should open a support ticket. Quote Link to comment Share on other sites More sharing options...
wyakram Posted June 6, 2025 Share Posted June 6, 2025 happens to me too Quote Link to comment Share on other sites More sharing options...
EddieTheTrooper Posted August 19, 2025 Share Posted August 19, 2025 I asked Line 6 Support about this issue. I was told to do factory reset. This has solved the problem, at least for now Quote Link to comment Share on other sites More sharing options...
