Isaac_Birks Posted June 5, 2025 Share Posted June 5, 2025 I would like to purchase a new patch. The website I'm hoping to buy it from only builds patches for HX Stomp however I own a HELIX. Can the HELIX accept HX Stomp patches? If not, is there of looking at the patch without owning / having access to an HX Stomp so that I can replicate the settings in an identical patch on the HELIX? Quote Link to comment Share on other sites More sharing options...
silverhead Posted June 5, 2025 Share Posted June 5, 2025 Yes you can get an HX Stomp patch onto Helix. I’m not sure that it can be done directly using HX Edit. Perhaps it can, but you can certainly use a trial version of Helix Native to either create a Helix-compatible patch or at least to inspect and manually recreate it. 1 Quote Link to comment Share on other sites More sharing options...
datacommando Posted June 5, 2025 Share Posted June 5, 2025 On 6/5/2025 at 11:46 AM, Isaac_Birks said: I would like to purchase a new patch. The website I'm hoping to buy it from only builds patches for HX Stomp however I own a HELIX. Can the HELIX accept HX Stomp patches? If not, is there of looking at the patch without owning / having access to an HX Stomp so that I can replicate the settings in an identical patch on the HELIX? Hi, Yes, no problem, providing you are using the latest version of the Firmware there shouldn't be any issues. Connect your Helix to your computer via USB, then simply drag and drop the preset .hlx file into an empty "New Preset" slot (or overwrite and existing one). It should then appear on your hardware. Done. Note: The Helix uses 2 DSP chips whereas the the HX Stomp is limited to a single chip. This means that a preset intended for use on the Stomp, or XL, can only occupy blocks on a single path. It is also possible to create a preset on your Helix which uses only a single path, and provided it doesn't exceed the single DSP and block usage, it can be used in a single chip unit. Hope this helps/makes sense. 1 3 Quote Link to comment Share on other sites More sharing options...
EstelleScott Posted June 11, 2025 Share Posted June 11, 2025 On 6/5/2025 at 7:18 PM, datacommando said: Hi, Yes, no problem, providing you are using the latest version of the Firmware there shouldn't be any issues. Connect your Helix to your computer via USB, then simply drag and drop the preset .hlx file into an empty "New Preset" slot (or overwrite and existing one). It should then appear on your hardware. Done. Note: The Helix uses 2 DSP chips whereas the the HX Stomp is limited to a single chip. This means that a preset intended for use on the Stomp, or XL, can only occupy blocks on a single path. It is also possible to create a preset on your Helix which uses only a single path, and provided it doesn't exceed the single DSP and block usage, it can be used in a single chip unit. Hope this helps/makes sense. Yes, you can import HX Stomp patches into Helix, but some tweaking may be needed. It’s a bit like adjusting limits, similar to what https://valismaa-kasiinod.com/rus/azartnyye-igry/snyat-zapret-v-kazino-v-estonii/ highlights, adapting for compatibility while preserving original intent is key in both cases. Thank you, you saved my day. 1 Quote Link to comment Share on other sites More sharing options...
datacommando Posted June 11, 2025 Share Posted June 11, 2025 On 6/11/2025 at 1:50 PM, EstelleScott said: Thank you, you saved my day. Hi, No problem - happy to help, and if you don't know you just have to ask, or have a read through the Helix manual - it's free! Helix floor, and rack, are the HX flagship units and they are fully spec'd. They should be able to load anything created for a single DSP unit, and it should then appear only on the A Path of your device, which still gives you a spare DSP on Path B, allowing you to add even more FX should you wish. Link: https://line6.com/data/6/0a00051afda2673ccc1cc8e68/application/pdf/Helix 3.80 Owner's Manual - English .pdf See page 5 - Preset Sharing with Helix/HX Devices & Helix Native Plugin. Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
Isaac_Birks Posted June 13, 2025 Author Share Posted June 13, 2025 This is great! Thank you so much @datacommando, much appreciated :) 1 Quote Link to comment Share on other sites More sharing options...
