hx stomp hybrid stereo setup with stereo direct out and two amps or a 7 cable method
Glonjo
Is HX stomp capable to do a hybrid stereo setup? Going stereo direct in to PA and in to two amps (without amp sim and IR).
Or can it do a 7 cable method?
  • Glonjo changed the title to hx stomp hybrid stereo setup with stereo direct out and two amps or a 7 cable method
Yes.
Stereo Balanced signal to FOH from the Main Outs, Stereo Unbalanced signal from the FX Loop to dual amps.
Place the Dual IR/Cab Block after the Stereo FX Loop Block.
The amp block is MONO, so anything before the amp block will be summed to MONO.
You COULD use a split path with two amps for end-to-end stereo, but the main drawback to your entire plan is that you'll quickly run out of DSP and you're already down to 5 blocks with the single amp/FX Loop/IR blocks.
7cm will work, but you'd need a stereo IR/DI box after the Main Outs (which go to the amp RETURNS) to add FOH without the CAB/IR getting to the stage amps.
Dual powered FRFRs instead of guitar amps would work fine.
Just to clarify, since you originally asked about going to a PA (FOH) -
Using Helix amps:
a single amp with pre amp fx in MONO, stereo post amp fx out to dual guitar amps using their fx loop returns should not be a DSP issue.
Using TWO Helix amps for end-to-end stereo will almost definitely be a DSP problem.
In neither case would the FOH routing affect DSP.
