Trying to run to amps via 7cm or 5cm. Help!
Samdbl
I’m trying to get stereo effects (from a Hx Effects unit) running through two different amps effects loops. I have followed directions, best I can, to do this via the 7cm and the 5cm. I spent all night doing it, and never got the formula correct. I’m sure I had the physical connections correct. I think it was the internal routing that were off. The most I got were low level effected signal coming out of one channel/side. At one point I had a clean signal on one side and wet signal on the other.
Could someone please give a clear, step by step of how I need the patch to be routed. I just had one pat with a stereo fx loop in a block before a string of stereo effects.
Ps the 5 cable method looks intriguing to me, as it’s less cables and possibly less phasing issues. I think it’s where you slave one Amps preamp to another’s power amp, and spread the effects over the two. However I only found one video on that. I tried to follow directions. But that is the scenario where I had a clean signal from one amp (clean as in, no preamp distortion or effects) and were from the other.
i just want a method that works smoothly.
Have you managed to do the 4CM with one of your amps?
If so connect the Out R with your other amp's Return - that's all to get the 5CM.
For the 7CM replace the FX Loop block with the stereo FX Loop block, connect as seen on page 10 of the 3.8 manual and you should be good.
Ok, I got it going, more or less. Two problems I'm now having
It seems like all of the effects are distributed evenly between the two amps. But for some reason, the reverb block is only coming out of one amp. It's a stereo block. At the end of a series chain. I've tried other reverbs. They're all doing the same thing.
Secondly, I'm getting some weird buzz/noise stuff. I assume that could grounding or loop issues I'll have to track down.
