Stomp XL - humming into powered monitor?
mtnman82
Using the same power conditioner and speaker (QSC K12.2) as my rack unit.  Rack unit is clean as can be.  Stomp XL hums like a mo fo when USB is plugged into computer.  Should I exchange units?
It's a ground loop issue. What you're hearing is the (alternating) voltage between the computer's USB ground and the QSC's ground.
Connect the computer's USB ground to mains ground.
Alternatively a line isolator like the Behringer HD 400 / Pyle PHD 300 or something like that between HX and QSC does the job.
A TRS cable with cut sleeve / ground lift should also work.
