FuzE_gus Posted August 12, 2025 Share Posted August 12, 2025 I'm going crazy. Running Helix Native on a Mac Studio M2 Ultra running the latest version of Logic Pro. OS Version: Sequoia 15.1 I've searched high and low and can't find anything on this. If a post exists on this somewhere, my apologies. Perhaps you could direct me. I hadn't used Native in a while and it wouldn't load properly so I deleted it and did a fresh install. The plugin loads but every time I try and open a preset I get this error: HELIX NATIVE Failed to load preset. Could not decrypt the asset. [code -1116] I've done multiple fresh instals after deleting all related files. I've double checked that the plugin is authorized. I just can't get this working. Any help would be GREATLY appreciated! Quote Link to comment Share on other sites More sharing options...
silverhead Posted August 13, 2025 Share Posted August 13, 2025 The message indicates that the preset is a protected asset, likely purchased from Line 6 Marketplace. Seems Helix Native does not recognize the license. Log into your Line 6 account within Helix Native and try again. 1 1 Quote Link to comment Share on other sites More sharing options...
datacommando Posted August 13, 2025 Share Posted August 13, 2025 On 8/13/2025 at 12:46 AM, FuzE_gus said: I'm going crazy. Running Helix Native on a Mac Studio M2 Ultra running the latest version of Logic Pro. OS Version: Sequoia 15.1 I've searched high and low and can't find anything on this. If a post exists on this somewhere, my apologies. Perhaps you could direct me. I hadn't used Native in a while and it wouldn't load properly so I deleted it and did a fresh install. The plugin loads but every time I try and open a preset I get this error: HELIX NATIVE Failed to load preset. Could not decrypt the asset. [code -1116] I've done multiple fresh instals after deleting all related files. I've double checked that the plugin is authorized. I just can't get this working. Any help would be GREATLY appreciated! Hi, There are several mentions of the [code -1116] in here, in fact the post prior to yours also references it. Anyhow, you said that you have tried a fresh install of Native, but there can be issues, especially on Mac units, where some items are not fully removed. Check this link: Another known issue, is if you change the name of your computer. Also, check here: More info regarding that code -1116 Hope this helps/makes sense. 1 Quote Link to comment Share on other sites More sharing options...
FuzE_gus Posted August 13, 2025 Author Share Posted August 13, 2025 Customer support got me sorted super quick... I did a preset purge and than restored factory setlists and everything is working again. I didn't have any presets saved so this was an easy fix. If I did I would have done a backup first. How to get those back? No idea, that would be a topic for another thread:) Thanks to all of you that jumped in here! 1 Quote Link to comment Share on other sites More sharing options...
