Does the POD Express get powered the same way as the POD GO?
daveaphotopod
Apologies if this has been answered, but I took a peek and didn't see anything. So, here's the thing. I've watched older videos on the CS6 power supply where we have to use the "red" cable (polarity) and the green cable to adapt to line 6. But then I am peeking at the back of the POD GO right now and it's center negative. Unless I am reading that wrong. But then I looked at the Blues Driver I have and that's the same icon!!
I have not had issues, and I assume of course that Truetone/1spot knows their stuff, so I must just suck at reading icons.
Having said all that, I confused myself. I have a POD Express coming in soon and I don't know how to power it. I did check the manual and it says center negative. Soooooo.....does that mean I don't need the "red" cable?
For anyone that's confused, as I was, I sorted it out.
The BOSS and POD GO are the same (and it appears that POD EXPRESS is too. The reason the inverter is there is because that green adapter which allows the power to "fit" into the line 6 inverts the polarity. The red one inverts it back to negative. All that work because its just the size of the DC port, and how that cable is set up.
