guitarsenall Posted November 13, 2025 Share Posted November 13, 2025 Please add a phase-reversal parameter to the gain block. Flipping the phase (e.g., polarity) is a CRITICAL and effective strategy for fighting low-frequency feedback for acoustic guitars. There is no simple way to do this within the current Helix Floor. If I don't have the switch on my pickup, I am up the creek. The gain block is the simplest place to put it: an option for "negative gain". 1 Quote Link to comment Share on other sites More sharing options...
lou-kash Posted November 14, 2025 Share Posted November 14, 2025 Does this help? Quote Link to comment Share on other sites More sharing options...
lou-kash Posted November 14, 2025 Share Posted November 14, 2025 On 11/14/2025 at 12:36 AM, guitarsenall said: Please add Also, this is a user-to-user forum. To submit feature requests, go to https://line6.com/company/contact/productfeedback Quote Link to comment Share on other sites More sharing options...
Schmalle Posted November 14, 2025 Share Posted November 14, 2025 To invert the phase set up a Stereo Width block [Volume/Pan (Stereo)] like this: Width Center, LR Swap Off, Balance R100, Level 0.0dB, RPolarity Invert ...and use a (any) mono block after it. Why do I need a mono block after it you ask? With the above mentioned setting the inverted signal leaves the block on the right channel only (left muted). A mono block after it automatically sums L (no signal) and R (flipped phase signal). 1 Quote Link to comment Share on other sites More sharing options...
guitarsenall Posted November 14, 2025 Author Share Posted November 14, 2025 On 11/14/2025 at 2:28 AM, Schmalle said: To invert the phase set up a Stereo Width block [Volume/Pan (Stereo)] like this: Width Center, LR Swap Off, Balance R100, Level 0.0dB, RPolarity Invert... Genius. By "Width Center" do you mean set the width to 50%? or zero? Thanks. Quote Link to comment Share on other sites More sharing options...
Schmalle Posted November 14, 2025 Share Posted November 14, 2025 On 11/14/2025 at 3:10 PM, guitarsenall said: Genius. By "Width Center" do you mean set the width to 50%? or zero? Thanks. "Center" is 0%. Tip: Save the block as favorite for easy access and name it "FlipFlopper" or something even funnier. ;) Have fun. Quote Link to comment Share on other sites More sharing options...
