PaulTBaker Posted Tuesday at 07:51 PM Share Posted Tuesday at 07:51 PM I am connecting to my Stadium XL to my mac Stadium Edit by wifi. Before all changes from either inside Edit or on the floor unit would sync to each other. That is not happening now. For example, I click on a block (delay) in edit, the floor unit does not select that block. Is it supposed to be sync'd like the old one? The old one used USB to connect. I read somewhere that the stadium will not connect using USB now. Is that correct? Quote Link to comment Share on other sites More sharing options...
silverhead Posted Tuesday at 09:01 PM Share Posted Tuesday at 09:01 PM On 12/2/2025 at 2:51 PM, PaulTBaker said: … For example, I click on a block (delay) in edit, the floor unit does not select that block. Is it supposed to be sync'd like the old one? … I’ve also noticed that block selection doesn’t track/sync. I suppose it’s a minor bug. Open a support ticket to report it. On 12/2/2025 at 2:51 PM, PaulTBaker said: … The old one used USB to connect. I read somewhere that the stadium will not connect using USB now. Is that correct? Correct. I expect it will be implemented in a future update. Quote Link to comment Share on other sites More sharing options...
