level meters on focus view on amps
PaulTBaker
My levels are about the same. I wouldn’t worry about it unless you hear something you think isn’t right. I pay more attention to the signal level indicator in the Output block; if that turns red it means there’s clipping.
Also, you can test the output level meter (the one on the right thwt you refer to) in the Amp block. If it behaves like a normal level meter it might change colour to orange and then red as you raise the amp’s Drive/Gain, Master, and/or Channel levels. I don’t know if it actually does change, but if you can make it change colour then you can be confident everything’s OK as long as it stays green.
  • Thanks 1
