eenymason Posted April 22, 2014 Share Posted April 22, 2014 Hi all, I have had a problem re-appear after appearing to be "fixed". Appearances CAN be deceiving!!! I bought a 2nd hand 300, with the intention of transplanting the electrics into a strat clone. I had already replaced the jackplate on the 300, cos it appeared the 1/4" out didn't work, and the first two piezos would only give any "audible" signal after having being connected to the Pod HD500 for "X" minutes. I say "audible" as I could tune the guitar straight away using the Pod's tuner, but on engaging a patch, only string 3-6 would be "audible". This glitch would correct itself, sometimes quickly, sometimes after being connected for quite some minutes and the guitar was fully playable across all 6 strings. This in itself tells me, the problem wasn't a piezo problem, Even so I transplanted the 300's guts into a strat clone and in doing so upgraded the piezos to graphtechs. It was always my intention to do this, and I also did it with my 600 which was my "workhorse". After a bit of time and effort, re-doing, and re-checking my soldering, and the ground contacts, the 300 transplant was working fine, across all strings, volumes lowered on all strings to around 70% to match the output of the 600. Beautiful! Recently tho, the two intermittently "dead" strings problem has re-appeared. I can only figure it must be another contact (I think unlikely), or a PCB issue. The two strings come back "to life" at the same time. If it was prior (and still is) a PCB issue, why would it go away, then re-appear. Also I haven't checked it out audibly (ie with my ears), but I always plug the 1/4" out into the guitar input of a "Live 3" vocal effects pedal, and I'm pretty sure the light on the unit doesn't "go on" (showing input signal) when I play the 300 xplant, but it does when I play the 600 xplant. I need to check this too, as it could even be related. Any "idea" input would be appreciated. Quote Link to comment Share on other sites More sharing options...
amx05462 Posted April 22, 2014 Share Posted April 22, 2014 one of the places i would check is the wiring harness going from under the bridge to the main board. check where the wires go into the plug ends for anything loose. also be sure to check the ends that plug in for looseness as well. then i might check the solder joints of the plug in ends on your boards. one more thing the strings go right through the pcb board under your bridge i dont know how you have that board secured. withthe original bridge it was held in place with a screw. on the 600 i believe its double sided tape which insulates it. you want to see if the board is being pulled bu string pressure and possibly shorting against the bridge plate. i added electrical tape between that board and the bridge plate to ensure no shorts. also a second nut to lock the board in place. Quote Link to comment Share on other sites More sharing options...
eenymason Posted April 22, 2014 Author Share Posted April 22, 2014 one of the places i would check is the wiring harness going from under the bridge to the main board. check where the wires go into the plug ends for anything loose. also be sure to check the ends that plug in for looseness as well. then i might check the solder joints of the plug in ends on your boards. one more thing the strings go right through the pcb board under your bridge i dont know how you have that board secured. withthe original bridge it was held in place with a screw. on the 600 i believe its double sided tape which insulates it. you want to see if the board is being pulled bu string pressure and possibly shorting against the bridge plate. i added electrical tape between that board and the bridge plate to ensure no shorts. also a second nut to lock the board in place. Thanks for suggestions - tho I don't believe I have a problem with this. I actually moved the board from under the bridge to inside the body cavity. It's screwed in place with insulating rubber under it. With the 600 xplant, I bypassed that and plugged the Ghost connectors straight into the main PCB - no soldering necessary! Quote Link to comment Share on other sites More sharing options...
