Can this routing scenario be achieved w/Helix?
boynigel
Tell me if this can be done with Helix or H-Stadium:
I’d like to send a preamp/power amp block (along w/other effect blocks) out to an external power amp into a guitar cab via ¼” output, while simultaneously sending the same signal chain, with the addition of a speaker block/IR out to the board via the XLR output.
Due to the amount of effects blocks I’m using, I wouldn’t have enough CPU to create (near) identical paths on the individual A/B paths and give each path its own output assignment.  In a perfect world I’d be able to assign the cab block to just the XLR out, but I’m pretty sure that’s not doable.
And yes, this scenario may beg the question, “why” …which I’d rather not get into.  I’d just assume mike the cab and send that to the board, but unusual circumstances have that out of my control.
Can I suggest, cabs/irs close to last with any additional FoH sweetening after the sends as well. Eg i use compression, eq, and tape emulation a lot to get FoH 'right' but an amp/can arrangement would not need that.
