guitarwarsfan Posted January 13 Share Posted January 13 I'm having a problem with assigning wah fx. When I go to program wah onto EXP 1 it will only work in the snapshot I'm in. When I go to next snapshot in that preset the wah doesn't work. When I setup the wah in that snapshot the wah in the previous snapshot stops working. I've made sure it's set to global but issue still persists. This seems to happen only in random preset banks. Does anyone know a fix for this? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
mike-w Posted January 19 Share Posted January 19 This might be the solution. Hit the block on the Helix Stadium XL twice, to show the menu. At the bottom of the list, slide the Snapshot Bypass to the right. I think that will fix you issue. I was dealing with this yesterday. The "switch" seems backwards to me - on - towards the Snapshot Bypass label - is off, off - away - is on. Quote Link to comment Share on other sites More sharing options...
Nos402 Posted January 19 Share Posted January 19 On 1/19/2026 at 9:09 AM, mike-w said: This might be the solution. Hit the block on the Helix Stadium XL twice, to show the menu. At the bottom of the list, slide the Snapshot Bypass to the right. I think that will fix you issue. I was dealing with this yesterday. The "switch" seems backwards to me - on - towards the Snapshot Bypass label - is off, off - away - is on. I felt the same way! It worked in reverse from what I *thought* it meant. It's not "bypassing the snapshot control" it is meaning that snapshot control of the block's bypass state is on or off. I think. IIRC. Quote Link to comment Share on other sites More sharing options...
Mobi Posted September 21 Share Posted September 21 I have the exact same problem and not solved and the snapshot bypass was set to the right... please help! Quote Link to comment Share on other sites More sharing options...
