Dufrense Posted February 27 Share Posted February 27 Greetings! I have an issue with my Helix Stadium XL. I use it to record into Fender Studio Pro 8 (also tried this in Bandlab). I create a audiotrack in Studio Pro 8 and set it up to use USB 7 as input, but there is no signal at all. Using USB 1/2 works just fine, but switching to 7 or 8 there is absolutely no input to the track. On the Helix I have checked the settings and USB 7 is setup for re-amping for instrument 1 (also checked my patch and instrument 1 is the input to the patch) and USB 8 is setup for mic. This should work, but there is absolutly no signal. Patch output is Matrix 1/4, XLR and Phones. As already mentioned I tried this in Bandlab as well with no luck. I used this feature frequently on my old Helix Floor with zero issues. Any tips on this issue? I Googled it, but it does not seem to be a widespread issue. Any help most appriciated! Best Regards /Dufrense Quote Link to comment Share on other sites More sharing options...
silverhead Posted February 27 Share Posted February 27 This is a known bug that I encountered using Sonar (post Bandlab - free version) and reported. It also affects USB 3/4 and 5/6. It will be fixed in a future update. There is a workaround. As long as USB 1/2 is armed for recording on one track all other USB channels are available for selection on other tracks. Quote Link to comment Share on other sites More sharing options...
Dufrense Posted February 27 Author Share Posted February 27 Aha! Thanks for informing me, guess I will have to wait for this feature :) Thanks again! /Duf Quote Link to comment Share on other sites More sharing options...
henricus1180 Posted Wednesday at 03:34 PM Share Posted Wednesday at 03:34 PM I have the same issue but in Ableton Live, and the workaround doesn't work for me - I already had a track armed for 1/2, as I wanted to capture both the DI and the effects on separate tracks as described in the manual. The effected track from 1/2 records fine, but there is nothing on the DI track from 7. I have checked the Global Settings>Ins/Outs has 'Re-amp Src Out USB 7' set to Inst 1, and my guitar is plugged into Instrument 1. Ableton's Audio settings are using the ASIO config, and 7&8 are set up for Mono inputs. Input Channel is set to 7 for the DI track. Quote Link to comment Share on other sites More sharing options...
silverhead Posted Wednesday at 05:57 PM Share Posted Wednesday at 05:57 PM I don’t remember exactly. You may have to arm tracks with ALL USB channels selected (1/2, 3/4, 5/6, 7, and 8) before any other than 1/2 deliver a signal to your DAW. Quote Link to comment Share on other sites More sharing options...
henricus1180 Posted Wednesday at 11:02 PM Share Posted Wednesday at 11:02 PM OK, thanks for getting back to me. I have a sort of workaround whereby I add an extra (empty) path to my Stadium Preset, with the Input Block set to Instrument 1 and the Output Block set to USB 1/2 (with Global Ins/Outs for USB 1/2 changed to Direct Out). This lets me record a DI track from the empty path, while monitoring with the effects on the other path (Output still set to Matrix). I then change the USB 1/2 settings back, and re-amp immediately to get an initial version of a 'wet' track. This does seem a bit of a 'miss' though. There is a whole section of the manual dedicated to using USB7 or 8 for direct out in parallel with a stereo effected output on 1/2. It surprises me that there isn't more reference to this issue when I search for it, which makes me wonder if it only happens with specific use cases. Do you have any feedback from Line 6 for your bug report on either the scope of the issue (does it really affect everyone, or just particular DAWs etc), or the timescales of a fix? Thanks again, H Quote Link to comment Share on other sites More sharing options...
silverhead Posted Wednesday at 11:17 PM Share Posted Wednesday at 11:17 PM I believe it’s just particular DAWs. So it likely doesn’t affect too many users. I use Sonar and I have this issue. If it applied to everyone I’m sure we’d be seeing more reports here. Quote Link to comment Share on other sites More sharing options...
henricus1180 Posted 19 hours ago Share Posted 19 hours ago OK, thanks very much for your help. Quote Link to comment Share on other sites More sharing options...
henricus1180 Posted 18 hours ago Share Posted 18 hours ago I raised my own ticket with Line 6 to confirm it affects Ableton, and their response confirms the workaround provided by Silverhead: This is a bug with the additional USB audio busses (all after 1/2) -The workaround is to have a track or tracks with the "previous" USB busses armed in addition to the other USB outputs. For example : -USB 3-4 and 5-6 will not record without USB 1-2 armed, USB 7-8 needs to have all previous USB tracks armed in order to record in the DAW -this will be fixed in a future update -but we cannot provide any timescale for firmware updates and which fixes will be included in the next update Best regards Line 6 /Ampeg Support Europe 1 Quote Link to comment Share on other sites More sharing options...
