Powercab 112 input volume and HX Stomp XL output volume
rhythmicdevil
This post concerns Helix Native, HX Stomp XL, and Powercab, I am not sure exactly which forum to post in so I will start here. My goal is to use patches created with Helix Native on the HX Stomp XL into the Powercab without resorting to duplication, or snapshots as that will be too much to manage.
The issue that I am running into is that the output volumes for all my patches are level set to -12dB for recording. When I use those patches in the HX Stomp XL the output is not enough to drive the Powercabs input into the yellow. The output is set to line, and the main volume control is maxed. From the manual:
When the signal LED(s) turn yellow, the Powercab speaker system will have
the most realistic non-linear natural breakup characteristics.
I have to be missing something obvious here its escaping me. Any practical advice would be appreciated.
Thanks in advance.
I no longer have a Powercab but IIRC, I solved this problem by boosting the INPUT levels in the SYSTEM settings of the Powercab.
That's Global, so it will affect all presets.
In that case your options are limited.
May I ask, WHY are you using Native to create your presets vs doing it on the HXS using HX Edit?
I see no advantage to that.
If you use the HXS as your interface you can build your presets in HX Edit, record both the effected sound AND a dry track simultaneously for re-amping, and drag & drop your HXS presets to Native, or use presets you create in Native, but you only use Native for re-amping.
