Two pod go wireless pedals.
DWE2022
Hi. Played a gig last night and both guitar players  are using a pod go wireless system. At points the units were interfering with each other and the signals were mixing together. My volume could be controlled through the desk channel of the other guitarists.
also. My signal was cutting in and out even after his guitar was put through the wired setting.
is there a way for us both to use our wireless set ups in the same vicinity?
From the POD Go Wireless FAQ: (see top of this page Support -> KB and FAQs -> POD Go)
Q: How do I use multiple POD Go Wireless systems?
A: Up to four POD Go Wireless and/or standalone Line 6 Relay wireless systems can be used on the same stage. However, care should be taken to ensure all systems are set up properly:
1. For the first system, connect the G10T transmitter to the POD Go Wireless GUITAR IN jack and wait 10 to 15 seconds.
Make sure the transmitter’s LED lights green.
2. Connect the transmitter to your guitar’s output.
3. Before the first transmitter goes to sleep (after 4 minutes of no audio input), repeat the above steps 1 and 2 for any additional POD Go Wireless systems.
Each system’s scanning procedure works around other active wireless channels to help ensure high quality performance for all systems.
  • Thanks 1
